High School Do We Cross Infinity When Moving from A to B?
  • Thread starter Thread starter Deepak K Kapur
    Movement
The discussion revolves around the philosophical implications of moving from point A to point B, particularly in relation to Zeno's paradox. Participants assert that while there are infinitely many points between A and B, one can still traverse the finite distance in finite time. The paradox highlights that mathematical concepts of infinity do not impede physical movement, as motion is continuous and not merely a series of discrete jumps between points. The conversation emphasizes the importance of understanding mathematical principles to resolve such paradoxes.
  • Understanding of Zeno's paradox, particularly "Achilles and the tortoise."
  • Familiarity with concepts of continuity in mathematics.
  • Basic knowledge of mathematical limits and infinitesimals.
  • Awareness of the philosophical implications of mathematical models in describing reality.
  • Study the mathematical foundations of Zeno's paradox and its implications in calculus.
  • Explore the concept of limits in calculus to understand how they relate to motion and distance.
  • Investigate the philosophical discussions surrounding the nature of infinity in mathematics.
  • Read advanced texts on the continuum hypothesis and its implications in physics and mathematics.
Philosophers, mathematicians, physics students, and anyone interested in the intersection of mathematics and physical reality will benefit from this discussion.
Deepak K Kapur
Hi
Any line joining points A and B has infinite points.
So, when I move from A to B, do I cross infinity?
What exactly do you mean by "cross infinity"?
Deepak K Kapur said:
Hi
No. You cross the finite distance between A and B.
You cross an infinite number of infinitely small distances. They cancel out.
Likes russ_watters and Dale
Thanks for responses..
I mean if I 'move point by point from A' i.e one point at a time, can I reach B?
What do you mean by 'they cancel out'?
Thanks.
I highly suggest you read the Wikipedia article on Zeno's paradox, that is "Aristotle and the tortoise". That's what you are asking here essentially.
Likes gmax137, russ_watters, FactChecker and 2 others
I mean do I travel an infinity of points when I move from A to B?
You do pass through an infinite number of points, but you also pass through a finite distance in a finite amount of time.
@rumborak's advice about reading up on Zeno's paradox is good - don't post again until you've followed it.
I think it's more commonly known as "Achilles and the tortoise." IIRC Aristotle wasn't much of an athlete. :oldwink:
Likes Nugatory and rumborak
I have read this article with things like dichotomy, arrow paradox, heap paradox, grain of millet etc.etc.
But... Still my question is
Space is continuous and therefore there are infinite points between A and B. If I move from A to B point by point, how can I ever reach B.
Thanks.
Don't let the math confuse you. Points are mathematical objects that help us describe the universe. The fact that there are an infinite amount of points between A and B simply doesn't stop you from moving between A and B.
Your post has raised a few questions in my mind...
1. It means math does not describe nature fully/accurately. If so what about all the equations of Physics that contain an awesome amount of math?
2. What is it that stops any physical distance from being infinitely divided. If you say it's the plank's length, what is the reason for not being able to go smaller than the plank's length?
Please don't mind but your post seems to be faith oriented and not logic oriented...
Thanks.
On the contrary. The math works just fine. There is nothing else that describes the universe more accurately that the correct application of math. I think the issue here is that you're searching for an 'intuitive' answer when there really isn't one.
To elaborate a bit on my previous post, this is actually a well known 'paradox' and there really isn't a single solution to it outside of math. Obviously we can move from point A to point B. Since we model the universe using math which uses 'points', it follows that even though there are an infinite number of points in between A and B, we also travel through all of these points as we move from A to B. The resolution is simply to accept this as a fact, much like how we accept certain things as axioms in math. Math deals with infinities and infinitesimals just fine and there's nothing paradoxical about moving between two points from the standpoint of math.
This 'resolution' may not be the one you wanted or even be a resolution at all, but I feel it's the only real answer you can get. We have to start somewhere after all. So when I say that you shouldn't let the math confuse you, I mean that this is a confusing situation with no clear answer outside of math and you shouldn't worry too much about it. Not everything is going to have an easy answer and sometimes there simply isn't an answer at all. Which is perfectly okay.
2. What is it that stops any physical distance from being infinitely divided. If you say it's the plank's length, what is the reason for not being able to go beyond the plank's length?
Nothing stops an arbitrary distance from being divided into smaller distances. But realize that we aren't taking some physical object and cutting it into pieces. We're talking about math. As long as we model space as being a continuum, there we can divide any distance up however we want.
By this what you really mean is that the explanation doesn't fit your logic. And I don't mean to negatively criticize or to insult, but to bring it to your attention that our own personal logic is very rarely the same logic that math and science uses.
Likes hernando Jose
@Drakkith
Great many thanks for such a considerate answer.
I think I will have to accept this as a mystery even more deeper and confusion than the 'cause of big bang'
If there are an infinite number of points then each is infinitely small. So if you move point-to-point you move infinitely slowly. So I'd say no you won't reach B. At least not in finite time.
There is no "sequence" of point to point moves that both touches all points in an interval and respects the natural ordering of the reals.
[A sequence as is commonly understood -- where each step is indexed by a countable step number]
Think of it this way . You are walking from A to B . The path between A and B has graduation lines like a tape measure . Your rate of progress from A to B is just set by your natural walking speed . In moving from A to B you pass over all the graduation lines - no matter how many there are - but the graduation lines on the path have no effect at all on your walking speed ..
The Wikipedia article on Zeno's paradox has several counterarguments, but I particularly liked the one that pointed out that these "infinite points" arguments implicitly consider the object at rest at each exact point, i.e. that the object kinda jump from one point to the next. That already is erroneous; the motion is an irreducible aspect of the object. That is, you can place as many markers on the smooth motion of an object, even infinity, but that doesn't mean you're reducing motion into a collection of point jumps.
@Drakkith
I would prefer if you learned it instead of thinking it was illogical and that you have to accept it on faith. This issue is not difficult. It ain't quantum mechanics!
Try this: if you need to measure the length of a 1m object and have a choice of meter sticks with tick marks in meters, centimeters, millimeters or micrometers, does your choice of meter stick change the length you are measuring?
Only if you don't divide the time intervals by the same factor as you divide the distance intervals.
Likes gmax137
This is probably partially the usual "does physics/math describe reality, or only reality's phenomena?" discussion. Points, limits (in the mathematical sense) etc are excellent tools to describe all of our experiments, but that in turn does not necessarily mean they are physically "real" (nor does physics make a claim that they are). In that sense, one must be careful using those mathematical tools for thought experiments like this.
Perhaps that could be put another way. The initial description of the phenomenon is where the problem starts. The situation cannot be described in terms of finite steps because it is a continuum of states. Initially describing it in the wrong way is what introduces the 'paradox'. Maths should not beat itself up about this.
Maths is no more an artificial description of the 'real world' than any 'verbal / hand waving description. It is better in (i suggest) every case because it is more rigorous.
Likes Drakkith
You are right. The length will not change.
But suppose..
I use infinitometers (infinitely small unit of length), would I be able to measure the length of the said object?
Thanks.
Deepak,
it is tempting to think about infinities, but without the proper math, these types of discussions often descend into contradictions and nonsensical answers.
If you *actually* want to know, you will not get around than to pick up a textbook and try to learn the math necessary.
But suppose..
The point is that it doesn't matter how many points there are (how small the divisions are), the length does not change: it is still just 1 meter. Even if there are an infinite number of points -- which there are.
Likes sophiecentaur
I think the question is not of the sameness of
length but that of 'traversing' the said length...
If the length is always the same, then traversing it is always the same. Take a large step. Did you just tavel 1m, 100cm or 1000mm? All of them: they are all the same.
I may be wrong but by 'traversing' I mean point by point 'traversing'.
If point are infinite, point by point 'traversing' cannot take me from A to B. Infact, I think I even will not be able to move from A in this way.
How does this relate to your original question? Aren't we talking about reality here? If you take 1 step, you take one step. Not 100, not 1000, not a million, not infinity, one. That's reality. It is almost like you are trying to disprove reality by making up a scenario that isn't reality and disproving that!
[edit] From your second post (which it doesn't appear anyone really answered directly):
No. But so what? You don't do that. You can't do that -- the way you actually move is different. So what use does this question have?
Likes rumborak
  • · Replies 31 ·
30K
