Estimate Microbial Number: MPN Method for CFU
  • Thread starter Thread starter frankmp40
    Method
When estimating microbial numbers using the MPN method, there is a debate on whether to use the counts from tube 3 alone or to average the counts from tubes 2 and 3. Some participants suggest that averaging can minimize errors, while others emphasize the importance of understanding the relationship between the counts in the two tubes, which is often a factor of ten. The discussion also highlights the need for clarity in calculations, particularly regarding whether to use raw data or processed averages. Ultimately, the choice between using a single count or an average depends on the specific context and the goal of the estimation. Accurate estimation is crucial for reliable microbial analysis.
frankmp40
Hi,
I just want to know should I only use counts in tube3 to estimate microbial number, or the average of tube2 and tube3 estimation.
Thank you!
What do you think you should do? Do you have any reason to suspect doing it one way or the other?
Also, when you say averaging the counts do you mean the raw data from each tube? Just to be clear, are you saying you will calculate, for example, (42+4)/2?
I mean now I have two estimation:
First one is No. of coliform = 39*dilution factor 1
The second one is No. of coliform = 241*dilution factor 2
Which estimation should I use, or I need to take the average of the two?
We can't just offer you an answer, we are here to help you work through your problem and actually learn something.
So I will reiterate my questions above. Do you have any thoughts or reasoning for averaging or not averaging the two measurements? In an ideal world, do you think there should be some relationship between the counts in tube 2 and tube 3?
I think the relationship between tube2 and tube3 is a factor of ten.
I would prefer their average as it can minimize errors.
I agree with both of the statements you made and would proceed accordingly if I were doing this.
Likes 1 person
  • · Replies 23 ·
  • · Replies 17 ·
