Multiplying Radicals with FOIL Method
  • Thread starter Thread starter zelda1850
    Radical
13 replies · 2K views
zelda1850
tried to solve the problem with foil method but i got confuse can someone help
1) (-7 + [tex]\sqrt{3x}[/tex])( 4+ [tex]\sqrt{3x}[/tex])
-7 * 4 = -28
-7 * [tex]\sqrt{3x}[/tex] = -7[tex]\sqrt{3x}[/tex]
[tex]\sqrt{3x}[/tex] * 4 = 4[tex]\sqrt{3x}[/tex]
[tex]\sqrt{3x}[/tex] * [tex]\sqrt{3x}[/tex] - does this equal [tex]\sqrt{3x}[/tex] square or is it just 3x or leave it [tex]\sqrt{3x}[/tex]
this is what i got so far
= -28 + -7[tex]\sqrt{3x}[/tex] + 4[tex]\sqrt{3x}[/tex] + [tex]\sqrt{3x}[/tex]
-7[tex]\sqrt{3x}[/tex] + 4[tex]\sqrt{3x}[/tex] = 3[tex]\sqrt{3x}[/tex]
= -28 + 3[tex]\sqrt{3x}[/tex] + [tex]\sqrt{3x}[/tex]
-7 * 4 = -28
[tex](\sqrt{3x})(\sqrt{3x})= (\sqrt{3x})^2= 3x[/tex]
No, [tex]-7\sqrt{3x}+ 4\sqrt{3x}= -3\sqrt{3x}[/tex]
[tex]-28- 3\sqrt{3x}+ 3x[/tex]
By the way, I think you will find that formulas look better if you put tex tags around the entire formula, not just "bits".
ok can someone check if I am doing these questions correctly now?
1) ([tex]\sqrt{2a}[/tex] -5)([tex]7\sqrt{2a}[/tex] - 5)
[tex]\sqrt{2a}[/tex] * [tex]7\sqrt{2a}[/tex] = 7 * 2a = 14a
[tex]\sqrt{2a}[/tex] * 5 = 5[tex]\sqrt{2a}[/tex]
5 * [tex]7\sqrt{2a}[/tex] = 35[tex]\sqrt{2a}[/tex]
5 * 5 = 25
= [tex]35\sqrt{2a}[/tex] - [tex]5\sqrt{2a}[/tex] = [tex]30\sqrt{2a}[/tex]
= 14a + [tex]30\sqrt{2a}[/tex] - 25
2) (2 + [tex]\sqrt{5}[/tex])( -2 + [tex]\sqrt{5k}[/tex])
2 * -2 = -4
2 * [tex]\sqrt{5k}[/tex] = [tex]2\sqrt{5k}[/tex]
[tex]\sqrt{5}[/tex] * -2 = [tex]-2\sqrt{5}[/tex]
[tex]\sqrt{5}[/tex] * [tex]\sqrt{5k}[/tex] = 25k
= -4 + [tex]2\sqrt{5k}[/tex] - [tex]-2\sqrt{5}[/tex] + 25k
You could use one or two more steps in #2. Possibly combine like terms of square root of 5.
[tex]-4 + 2\sqrt{5k}-2\sqrt{5}+25k[/tex]
[tex]-4 + (\sqrt{k}-1)2\sqrt{5} + 25k[/tex]
im not sure what the like terms would be
Are you sure there isn't a typo in the first radical? I think the problem might actually be this:
[tex](2 + \sqrt{5k})(-2 + \sqrt{5k})[/tex]
zelda1850 said:
2 * -2 = -4
Don't put this stuff in as separate steps. We all know that 2 * (-2) = -4 and there is absolutely no advantage in writing [itex]2 *\sqrt{5k} = 2\sqrt{5k}[/itex].
There should be an unbroken line of expressions connected by =, ending when you have reached the simplest form of your beginning expression. Putting in these baby steps makes it more difficult to follow your work, because it isn't clear what the original expression is actually equal to.
that was the right question so can someone tell me what i did wrong?
oh how can i correct it would it be sqaure root 25k?
Yes, that would be correct: [tex]\sqrt{5}\sqrt{5k}=\sqrt{25k}=5\sqrt{k}[/tex]
can i add [tex]2\sqrt{5k}[/tex] + [tex]5\sqrt{k}[/tex] or it doesn't work
so my answer would be
-4 + [tex]2\sqrt{5k}[/tex] - [tex]2\sqrt{5}[/tex] + [tex]5\sqrt{k}[/tex]
