MyList[[ 1, 3, 2 ]] using ind = {1, 3, 2}
  • Topic: Mathematica
  • Thread starter Swamp Thing
Swamp Thing
Insights Author
Given a list of indices ind = {1, 3, 2} , is there a shortcut to this? :--
Code:
MyList[[ ind[[1]], ind[[2]], ind[[3]] ]]
Not list comprehension, but something much simpler.
It's about Mathematica, indexing into a list.
Normally, you do MyList [[ m, n, o ]] when the indices m, n, o are available in variables. But if m, n, o are contained in a list like lst={1,3,2} then is there a more compact alternative to the code in my OP?
In MATLAB, syntax like arr(ind) is accepted, where ind is an array of indexes of arr.
Matlab:
>> arr1 = [5 9 10 7 6 ];
>> ind = [1 3 2];
>> arr1(ind)
ans =
     5    10     9
Have you tried something like MyList [[ lst ]], a rough equivalent of the above MATLAB code?
Code:
Code:
MyList[[ Sequence @@ ind ]]
If MyList is multidimensional, the above will pull out rows 1, 3 and 2. What I'm looking for is to pull out the single element MyList[[1, 3, 2]].
Thank you.
I'm now experimenting with @@, which I am meeting here for the first time.
What is going on here:
Code:
Sqrt @@ Sin[2]
Output:
##\sqrt{2}##
Code:
Sqrt @@ Sin[2.0001]
Output:
0.909256
Try FullForm on what you put right of @@.
Code:
FullForm[Sin[2]]
FullForm[Sin[2.0001]]
