Mysterious Motion of Galaxy Clusters Detected
The discussion revolves around the unexpected motion of distant galaxy clusters as detected by NASA's Wilkinson Microwave Anisotropy Probe (WMAP). Participants explore the implications of this motion, questioning established cosmological models and considering alternative theories, including pre-big bang scenarios and the limitations of the Lambda Cold Dark Matter (LCDM) model.
  • Some participants suggest that the observed motion might indicate a "slippery balloon" effect at extreme distances.
  • Others propose that this could be the first experimental sign supporting pre-big bang scenarios, potentially benefiting loop quantum gravity and string theories.
  • Several participants express skepticism about the current cosmological model, labeling it as "bankrupt" and questioning its assumptions regarding homogeneity.
  • Concerns are raised about the implications of non-homogeneity on the extrapolations made by the LCDM model, with some arguing that current explanations involving dark energy and dark matter are insufficient.
  • One participant emphasizes the need for mathematical tools to predict the consequences of non-linearity introduced by deviations from homogeneity.
  • Another participant discusses the Horizon Problem and critiques the reliance on inflationary scenarios to resolve it, suggesting that such models introduce further complications.
  • Some participants note that the signal-to-noise ratio of the findings is not convincing, indicating a need for caution in interpreting the results.
Participants express a range of views, with no clear consensus on the implications of the findings. While some see potential support for alternative models, others remain critical of the current cosmological framework and its assumptions.
The discussion highlights limitations in the current understanding of cosmological models, particularly regarding the assumptions of homogeneity and the implications of observed anomalies. There is an acknowledgment of unresolved mathematical steps and the speculative nature of some proposed theories.
wolram
Dearly Missed
http://www.sciencedaily.com/releases/2008/09/080923104410.htm
ScienceDaily (Sep. 24, 2008) — Using data from NASA's Wilkinson Microwave Anisotropy Probe (WMAP), scientists have identified an unexpected motion in distant galaxy clusters. The cause, they suggest, is the gravitational attraction of matter that lies beyond the observable universe.
The clusters show a small but measurable velocity that is independent of the universe's expansion and does not change as distances increase," says lead researcher Alexander Kashlinsky.
Space news on Phys.org
Is this the first sign of a slippery balloon at extreme distance?
Is this the first experimental sign for a pre-bigbang scenario, than it (might be)/is good news for both LQG bounce(s) and eventually also for also for stringtheories??!
Kind regards hurk4
To me yet another sign of an already bankrupt model.
In the thread linked below, I have raised some questions regarding the scope of the accepted mainstream model of cosmology. Therefore, would be interested in the scope of differing opinions with respect to this model.
https://www.physicsforums.com/showthread.php?t=269556
I would say it is early to read to much into this yet, i thought it interesting rather than
grand slam evidence of any thing.
That will be exciting if they confirm it. Turns out the universe is not as homogenious as the simple LCDM model assumes it to be.
The horizon is a long way out. So inverse square drop off in gravitation would detect how large of a mass 'beyond the horizon'? But how can one have an influence from beyond horizon? Even for our Local Group, if it's velocity in regards to CMB frame of reference is ~600 kms^-1, what mass would be required at what distance? Even the curvature from Virgo cluster is quite slight for our Local Group distance of ~50 Mlyrs.
The signal to noise ratio is not convincing.
The FRW model, which is the basis for the LCDM model, assumes perfect not just approximate homogeneity. Once it is not perfect, extrapolations are suspect as we have no mathematical tools to predict the consequences of the introduced non-linearity. Current proponents of the model just intuititively believe that those non linear effects will magically cancel out. Experimental discrepancies are "explained" by introducing things like dark energy, dark matter, dark flows etc. They conveniently state that those dark things cannot be directly observed which makes it equivalent to posing that Angels or Pink Unicorns influence the distances of heavenly objects.
You all might be interested in reading what Ned Wright had to say back in September about the two "Dark Flow" papers by Kashlinski et al. His note gives links to the papers
http://www.astro.ucla.edu/~wright/dark-flow-errors.html
Yes, Yes, and Yes again. To add to difficulties, it seems to me that almost everyone has now long forgotten how contrived is the resolution of the Horizon Problem, using The Inflationary Scenario (if Scenario is a still-accepted euphimism).
As you say, Jennifer, the FLRW mode is the basis of LCDM cosmology. But the observed extent of homogeneity is glaringly incompatible with such cosmology --- that ]is the Horizon Problem. To resolve this impasse, then, one assumes that the observable universe was once only part of a homogeneous patch of a pre-inflationary universe. In this mad, unknowable universe the FRW model is thrown to the winds, seemingly without a thought, and replaced by what some folk happily postulate to be a multiverse seething with imhomogeneities that are conveniently now beyond our horizon ---- thanks to the inflationary device. This is where your Angels or Pink Unicorns come in, Jennifer, and is one reason why I cavil at writing about the consensus model as if it were dogma, Marcus.
oldman said:
... why I cavil at writing about the consensus model as if it were dogma, Marcus.
Have another look at my posts. I don't present consensus model as dogma. I have my own reservations about it (e.g. as one skeptical about inflation, I regularly report alternative solutions to horizon etc riddles---and I see no scientific reason to believe in the existence of a cosmological singularity since a onetime bounce model fits the data about equally well).
Obviously everybody is free to think whatever they please about the universe, what I've been proposing is that we start off with a common minimal understanding of the standard mainstream picture. It makes communication a lot easier if everybody understands what they are deviating from. And what they are being skeptical about.
You asked about inflation scenarios. AFAIK they are called scenarios to emphasize that they are not testable scientific theory---they solve some puzzles but in exchange present others---they have a certain mythical or speculative character at least for now. So they are called scenarios. Maybe ways to test and potentially rule out certain inflation schemes will be found, making them more like regular scientific theory.
Jennifer referred to the absence of perfect homogeneity. I don't think this vitiates the FLWR. It can still be a damn good approximation, and enormously useful even with only approximate uniformity.
If people are predisposed to utterly reject the standard model (rather than according provisional pragmatic partial acceptance) then they are likely to jump the gun when some news like Kashlinsky's "Dark Flow" comes out. Oh my! this shows how bankrupt the consensus model is! But I think it's probably wiser to wait before jumping, see Ned Wright's comment (I gave the link earlier.)
How was the Indian Ocean?
marcus said:
...what I've been proposing is that we start off with a common minimal understanding of the standard mainstream picture. It makes communication a lot easier if everybody understands what they are deviating from. And what they are being skeptical about... But (about dark flow) I think it's probably wiser to wait before jumping...
I support both comments. As to the Indian Ocean (at Umhlanga Rocks N. of Durban): Pretty good!
I concur with marcus. The Kashlinsky papers take considerable liberties with mainstream interpretations to draw extreme conclusions. Strangely enough, they rely on rigidly defined mainstream interpretations as their footings. I found this objectionable in their initial paper on this basis alone. Having now seen Ned Wright's comments, I am comfortable with my instincts on this one. I view it as a shotgun objection to mainstream physics - to wit, some underlying assumptions must at least be subtley flawed [or misinterpreted] to allow me to draw such a conclusion. I do not find that particularly shocking.
If I understand this correctly, gravitational waves from the “unobservable” part of the Universe are thought to be causing the dark flow in the observable part. But, the reason given for one part of the Universe to be unobservable is that the distance is so great that light cannot reach us; it is over the horizon. In that case, how is it that gravity is reaching us, if gravity travels at the speed of light?
It's basically a good question.
There was a time when matter that is now too far to see
was much closer to us
And then the pull of that matter might have started us drifting in some direction and we just continued by inertia.
If there is some lopsidedness, some unevenness in the distribution of matter, with some slight overdensity in some direction beyond our current horizon, well maybe we are not feeling that bunch of matter NOW but maybe it started us drifting back at a time when we did feel it.
But be careful! The current dark flow proposal has been poo-pooed and given the brush-off. Ned Wright is a pretty good authority and he found mistakes in the Kashlinsky paper. He says don't trust it. My advice it would be good not to talk as if you believe Kashlinksky. Don't start assuming that it is real. I gather others of us agree.
One thing to notice in any case is that the standard cosmo model is rather ROBUST in the sense that it can absorb some perturbations like this without being invalidated. George Ellis (an early collaborator of Hawking who is now a recognized cosmo expert) did an analysis back in 1998 of the robustness of the usual FLWR model. It is pretty tough and resilient. So if some future study does find evidence of some slight largescale inhomogeneity, and some slight drift, well this will be extremely interesting but probably will not change our basic outlook very much.
as a matter of vocabulary, when I hear people talking about "gravitational waves" they usually are talking about some little temporary ripples, not the overall steady pull. I agree with the idea that changes in the gravitational field travel at c, or no faster than light. I'm not being very clear about this, but I don't feel entirely comfortable with your phrasing your question in terms of gravitational waves. Maybe someone else will help clear this up. News doesn't travel faster than c. Information doesn't...I have to leave it here.
Schroder, your question raises some additional issues in my mind, which may be relevant to this thread. First, for clarification, I am assuming that the observable universe broadly aligns to the particle horizon associated with CMB decoupling. I believe this is estimated to be ~46 billion lightyears rather than the visible horizon at 13.7 billion lightyears?
However, I would have thought, in a homogeneous model, that these horizons are subjective to the position of the observer. As such, if I could magically and instantly transport to position-X some 47 billion lightyears in distance, I would be beyond our observable horizon, so what would this part of the universe look like? As I understand it, the homogeneous model would suggest that it would be similar to what we see from our current position, although from position-X, our home galaxy would be beyond their observable horizon.
o Therefore, I wouldn’t have thought that photons and gravity waves see our perception of a horizon as any form of a barrier. As such, couldn’t a remote galaxy within our observable universe be affected by structures that appear to be beyond our observable horizon, but within their subjective definition?
o In a perfect homogeneous model, all galaxies would be at rest with CMB. The fact that galaxies exist suggests that gravitational `anomalies` do exist and, as an extreme example, I understand that `The Great Attractor` is believed to account for a peculiar velocity of some 700 km/s. If so, could some enormous gravitational source beyond our observable horizon not conceptually be the source of another peculiar velocity, which the original article cited in #1 has dubbed `dark flow` even withstanding Ned Wright’s cited errors?
o Finally, as a general question, any thoughts on how many times I could repeat the conceptual jump of 46 billion lightyears, i.e. 46+46+46 etc, or does spatial geometry have something to say about this accumulating distance?​
It seems you are describing some form of cascaded gravity. I had not thought of that, but it does seem possible.
The homogeneous model (the FLRW model that relies on the cosmological principle) --- by itself --- can't explain homogeneity on a scale larger than halfway to our observable horizon, let alone to multiples of the horizon radius, because of the limited scale of causal contact inherent in the model. So even the observed scale of homogeneity is in conflict with the plain vanilla everywhere-isotropic model.
To resolve this problem one must incorporate inflation into the mix of speculation, thus extending the scale of homogeneity out to at least twice beyond what is observable. And who knows what lies beyond this? Boundaries, topological defects and a broken model? Or sea-serpents?
There should be a relation between the power spectrum on large angular scales and the peculiar velocities of bulk flows. They should be in conflict with the existing WMAP data for large scale density fluctuations. Is there any known attempt to relate this large scale flow to other recent conflicts of the WMAP large angular scale power (axis of evil, etc.)?
http://www.nasa.gov/centers/goddard/...dark_flow.html
WASHINGTON -- Using data from NASA's Wilkinson Microwave Anisotropy Probe (WMAP), scientists have identified an unexpected motion in distant galaxy clusters. The cause, they suggest, is the gravitational attraction of matter that lies beyond the observable universe.
"The clusters show a small but measurable velocity that is independent of the universe's expansion and does not change as distances increase," says lead researcher Alexander Kashlinsky at NASA's Goddard Space Flight Center in Greenbelt, Md. "We never expected to find anything like this."
arXiv:0811.3606 and arXiv:0811.3690
Same as in cosmic flow thread just below.
I am aware of that paper, but it does not answer my quetion. They do not relate this to any other postulated inconsistency in the large scale WMAP data, do they?
http://arxiv.org/PS_cache/arxiv/pdf/0811/0811.3606v2.pdf
Finally, we would like to comment on the fact that
the total quadrupole have a preferred axis which happens
to coincide with the direction of the velocities and,
as a consequence, with that of the dipole. Therefore,
a moving dark energy model could also shed some light
on the so-called axis of evil problem [15]. Although this
anomaly usually refers to the observed alignment of the
ℓ = 2−5 multipoles, there are also evidence that the axis
of such alignment is correlated to the dipole direction at
more than 99% C.L. [16]. Since moving dark energy gives
a common physical mechanism for both the dipole and
quadrupole contributions, it is expected to have correlations
among them. Indeed, in [10] it is shown that the
motion of dark energy could solve the low quadrupole
anomaly for some models of dark energy, in particular, for
scaling and null dark energy models.
Interesting, thanks wolram.
15K
14K
  • · Replies 17 ·
