Mystery Apparatus: Can You Identify It?
  • Thread starter Thread starter Scott Kozak
    Mystery
The discussion revolves around identifying a mysterious laboratory apparatus encountered by a physics teacher. The apparatus features vacuum tubes, brass plates, and coils, and its purpose and origin are unclear. Participants explore various hypotheses regarding its function and historical context, with a focus on its potential relation to radio demonstration equipment.
  • Scott describes the apparatus, noting its construction and dimensions, and expresses uncertainty about its function.
  • Some participants suggest that the vacuum tubes may be diodes used for rectification, contingent on further details about the wiring.
  • One participant identifies the apparatus as a receiver for a Radio Demonstration Apparatus, referencing an external source for confirmation.
  • Another participant discusses the potential age of the apparatus, suggesting it may be from the 1935–1950 period based on the tube type.
  • There is speculation about the specific type of vacuum tube used, with references to various models and their characteristics.
  • Participants express the need for additional views and information about the apparatus to refine their hypotheses.
While there is some agreement on the apparatus being related to radio demonstration equipment, participants have differing views on its exact identification and age. The discussion remains unresolved regarding the specific details and function of the apparatus.
Participants note limitations in identifying the apparatus due to missing details such as tube numbers and wiring configurations. The discussion also references historical catalogs, indicating potential discrepancies in the apparatus's age.
Scott Kozak
Hello everyone,
This is my second year teaching Physics and I have come upon an interesting apparatus that no one can seem to identify. It appears to be two vacuum tubes protruding from a casing which includes two sets of three parallel brass plates, presumably with some sort of dielectric in-between. These plates are in turn wired to what I believe is an insulated solenoid of unknown coil number. There is another coil of wire wrapped around a glass test tube connected in parallel to the bulbs and I think to the negative feed (although this connection seems to have worn out). It is made by the Central Scientific Company (Cenco), listed as a "laboratory apparatus" along with "supplies chemical." Dimensions are 30cm bulb to bulb with a 10 x16 cm base and stands 13 cm tall at its highest point (picture attached.
I haven't the slightest clue what this thing is or does but my students are absolutely fascinated with it. Can anyone help me Identify it.
Thanks,
Scott
Science news on Phys.org
Would be nice to have a side view and the underneath view of the wiring. Also, there are tube numbers that would be helpful. Initial ques is, the tubes are diodes being used to rectify the potential developed on the single brass loop (transformer secondary) from the coupling of the test-tube windings (transformer primary). But without seeing a side view, that could be completely wrong.
anorlunda's Central Scientific catalog is from 1918 and seems to be arranged alphabetically
page 421 is start of Pyrometers section
page 427 starts Radio Activity Apparatus (electroscopes)
page 433 is rubber goods
no radio equipment... so i think it's newer than 1918
Is there a number on the tubes? How many prongs , 4 ?
Could be a #30 triode , i have an old radio that uses them
https://frank.pocnet.net/sheets/021/3/30.pdf
seems the right flavor for a 1930-ish radio experimenter's tool
i can make out an RCA logo on one tube base but not a number. My #30's have the number on the glass envelope ~midway up.
@dlgoff - you 're the maestro !
old jim
dlgoff said:
Okay, it's the receiver of a Radio Demonstration Apparatus Generator and Receive. There is also the generator that would go with it.
See: http://www.radiomuseum.org/r/centralsc_radio_demonstration_appa.html
edit: here's a copy of their picture.
Thank you very much dlgoff and jim hardy. I really appreciate all the help and detective work. My students were becoming discouraged after they looked through the whole Cenco catalog and didn't find anything, they'll be thrilled to have the mystery solved!
