Need discussion about a heavy spring hanging down
  • Thread starter Thread starter akak.ak88
    Discussion Spring
A heavy spring, when hung from its top, experiences a nonuniform extension due to its mass, with greater stretch at the top compared to the bottom. The change in potential energy as the spring stretches must equal the potential energy stored in the spring when it comes to rest after oscillating. The weight of the spring varies linearly with the distance from the top, affecting how potential energy is distributed along its length. The system will oscillate until internal damping and air resistance dissipate the motion, leading to a slight increase in temperature from the work done on the spring. Understanding these concepts is crucial for solving related problems and preparing for assessments.
akak.ak88
Hang a heavy spring from it's top.
Let it hanging down naturally.
The total mass of the spring is M.
The spring constant of the spring is k.
Asking it's extension.
2. Homework Equations
Describing the potential energies( spring force energy or gravity)
with math or physics equation.
Describing the motion of the spring
Or please tell me everything you know or interesting about this heavy spring.
3.My professor told the whole class that he is going to put any questions about this heavy spring in our midterm test, so that I need many helps to let me know this heavy spring more clearly. This spring is so important to me.
One thing you know is that the distance the center of mass of the spring drops from its unstreached position represents a change in potential energy. When the spring comes to rest and quits oscillating, the aforementioned potential energy change must equal the stored potential energy in the spring.
When it comes to rest after oscillating, the stretch in the spring will be nonuniform. It'll stretch more where its fastened at the top than where it is attached to M. Potential energy is not stored equally throughout the spring. The storage of potential energy increases as you go upwards due to the additional stretch.
The weight expanding the spring coils varies linearly with the distance from the top due to the uniformity of the coils (assumed).
The system will oscillate up and down until the internal damping of the spring and air drag damp the motion out. The temperature of the spring will rise slightly due to the work being done on it by the constant bending of the material as the spring oscillates.
Thank your accurate concepts, which help me think more clearly
about the energy and motion.
I still have the problem about writing the formula or making assumption.
Could you please show me some initial formula about
the aforementioned potential energy change must equal the stored potential energy in the spring and how to describe the up and downs with the formula.
Really thank for answering, it really give me a good direction to think more.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
