Net force on falling person over braking distance
15 replies · 4K views · last reply
jg871
Problem #7[/B](Due 9/26 Friday by 8:00 a.m.)
Hydro, who has a mass of 45.1 kg, falls straight down 4.67 m to the water below.
a. If Hydro comes to rest .543 seconds after hitting the water, what was the net force exerted on Hydro over this time?
Looked in the book, read the sections the question pertains to, and am still lost. Any assistance with how to solve this would be appreciated.[/B]
jg871 said:
(4.67/.543) *45.1?
No.
What's the momentum of Hydro as he first touches the water?
Doc Al said:
No.
4.67/.543 so 8.60?
jg871 said:
4.67/.543 so 8.60?
Don't just give numbers--show how you used the basic formulas.
In any case, no. Answer this: If something falls a distance X, how fast is it going at that point?
Acceleration of gravity correct?
The acceleration of a falling object is g, the acceleration due to gravity. But what's the speed of the object after it falls?
I'm struggling mightily.
What may seem obvious is just not registering for me here
speed = distance / time
so
4.67m / 0.543s
but how do you get the acceleration from that?
I'm also working on this question for homework.
For the velocity vs. time graph, does your constant negative line start at some velocity above zero and stop at zero? Or does it go past zero into a negative, or does it start at zero and go down?
Wasn't very good at drawing these for the test either...
so
4.67m / 0.543s
Divide by time again
I wasn't either. Go to umd? I believe it goes into a negative but I'm confused with the class so far
That will give you average speed.
Ering said:
so
4.67m / 0.543s
You are dividing the distance it falls (before it hits the water) by the time it takes to come to rest (after it hits the water). That won't help.
Separate this problem into two parts: (1) How fast is it moving when it hits the water? (2) What net force does it have after it hits the water and is slowing down?
Solve each part separately.
The acceleration due to gravity is a constant. Look it up! (It's usually called g.)
