What is the energy dependence of photon cross sections at high energies?
  • Context: Graduate
  • Thread starter Thread starter daisey
    Mass Neutrino
The discussion centers on the energy dependence of photon cross sections at high energies, exploring the differences in interactions between photons and neutrinos with matter. Participants examine the implications of these interactions in various contexts, including theoretical and experimental aspects.
  • Some participants note that photons, being massless and electromagnetic force carriers, interact differently with matter compared to neutrinos, which are affected by the weak interaction.
  • It is proposed that very energetic photons can travel long distances before scattering, although the exact energy threshold for significant penetration is questioned.
  • Participants discuss the ability of ultra-high energy gamma rays to penetrate materials like superconductors, with some asserting that superconductors do not significantly screen gamma rays.
  • One participant presents a comparison of scattering mechanisms for photons and neutrinos, highlighting the differences in their interaction cross sections based on energy levels.
  • Another participant outlines three primary ways photons interact with matter, detailing the energy ranges for photoelectron emission, Compton scattering, and pair production.
Participants express differing views on the specifics of photon interactions with matter, particularly regarding the effects of superconductors and the energy dependence of photon cross sections. The discussion remains unresolved with multiple competing perspectives.
There are limitations in the discussion regarding the assumptions made about energy thresholds and the definitions of scattering mechanisms. Some participants reference specific energy ranges without fully resolving the implications of these interactions.
daisey
Hello All,
I have read that because the Neutrino has so little mass, and because it is not affected by the Electromagnetic Force that it can travel through light years of solid lead. The photon is also mass-less, I believe. Why can it not do the same as neutrinos? I understand the photon is the force carrier for the electromagnetic force. Does that mean the photon is so affected by the force that it represents that it cannot travel through lead as a neutrino can?
yes, the photon has electromagnetic interactions, which is stronger than the weak interaction.
daisey said:
Hello All,
A very very energetic photon can travel long way before scattering.
Bob.
Bob.
How energetic? Can an ultra-high energy gamma ray photon penetrate through half an inch of a superconductor. A neutrino can pass through that and more.
Zz.
Zz.
Yes, it certainly can. A superconducting state cannot prevent a photon from having a very small scattering cross section. A superconductor does not screen the gamma rays.
Bob.
Bob.
Can you cite a reference for that, considering that the photon's E-field could be easily shielded by the supercurrent?
Zz.
ZapperZ, the problem is that the supercurrent doesn't "see" frequencies as high (or equivalently as wavelengths as short) as you get in gamma rays (or even x-rays).
The photon couples directly to charged particles, namely, electrons and quarks.
The neutrino doesn't. It interacts by exchanging a W or a Z boson.
If we compare two main mechanisms: scattering of a photon on an electron (Compton scattering), and scattering of a neutrino on an electron, ignoring loop effects and dimensionless factors of magnitude one, we'll see that the amplitude of the first process is ~1/E_{cm}^2 and the amplitude of the second process is ~1/(E_{cm}^2+m_X^2) where m_X is mass of W or Z boson and E_{cm} is center of mass energy. If all energies are high enough to consider electrons massless (>>1 MeV), cross section is proportional to M^2/E_{cm}^2.
Obviously, for energies well below W/Z masses, neutrino-electron cross section will be lower than photon-electron cross section by the factor of (M_X/E_{cm})^4. Comparing a 10 MeV solar neutrino with a 10 MeV photon, we get a factor of 10^16. Which explains why a 10 MeV photon will travel a few centimeters in the matter before stopping, and a 10 MeV neutrino is likely to fly through the Earth without stopping.
What is the energy-dependence of the photon cross section at height E? Doesn't it decrease?
Bob.
That could be it. After all, the AC resistivity certainly goes up with increasing frequency.
Thanks!
Zz.
Bob_for_short said:
What is the energy-dependence of the photon cross section at height E? Doesn't it decrease?Bob.
There are three primary ways photons interact with matter: 1) Photoelectron emission. This the highest cross section from 1 or 2 eV up to just beyond the k-shell electron binding energy 2)Comption scattering. Cross section (roughly 2/3 barn. Most dominant cross section up to several MeV. 3) pair production. The most dominant cross section above several MeZV.
There are also photon-nuclear cross sections, such as gamma-n on oxygen, which reaches a maximum (a few barns) between 10 and 20 MeV.
