New EM spectrum designation between UV and X-rays
  • Context: Undergrad
  • Thread starter Thread starter nightvidcole
5 replies · 1K views
nightvidcole
TL;DR
Spectral region straddling the boundary between UV and X-rays has unique challenges - everything is opaque. I argue it deserves "promotion" to a spectral region of its own.
I propose a pedagogically useful, and physically and economically descriptive region between UV and X-rays (or, if you like, straddling the boundary between the two).
The basic physics here is dramatically different from both "traditional" UV and "traditional" X-rays, because of one very important thing - all normal matter, made of atoms, is extraordinarily opaque in this spectral region due to the photoelectric effect. A single millimeter of air, or a micrometer of solid or liquid, blocks the vast majority of this radiation. There is no other spectral region like this.
In fact, the photoelectric absorption is so strong that even astronomical observations can be suppressed due to extremely tiny amounts of intervening matter.
This means that until EUV lithography became a thing, commercial applications for this radiation were nearly nonexistent, as its use is limited to outer space and vacuum chambers. Yet, science textbooks simply place UV next to X rays, as though there is a smooth transition from suntans to radiographs. But they leave out the fact that both suntans and radiographs are possible only because at least some matter is partially transparent for "traditional" UV and "traditional" X-rays, and there is this unmentioned region in between where nothing like either is possible.
One could argue that we already have names like "XUV" and "soft X rays". This is technically true, but it doesn't really quite do justice. One could also argue that terahertz radiation never needed a designation because it was "just" mm-wave on one side and far infrared on the other. But this would downplay the unique challenges with this region. Likewise, the unique nature of the UV/X-ray boundary region is downplayed by not recognizing it as distinct.
I would even go so far as to argue that there is somewhat of a "gap" in this region just as there is a "gap" for terahertz technologies. To be specific, ordinary "optical" technologies cannot be extended cleanly into this region because they do not work when all matter has such high attenuation. "X ray" technologies would be extremely inefficient when operated in this region, as (non-thermal) bremsstrahlung energy efficiency is tiny for photons of such low energy. Just like with Terahertz, we are left with only extremely inefficient, low-power, or non-compact sources for this region.
Thoughts?
nightvidcole said:
TL;DR: Spectral region straddling the boundary between UV and X-rays has unique challenges - everything is opaque. I argue it deserves "promotion" to a spectral region of its own.
Can you be more definite? What specific two wavelengths would you use to define the edges of this new spectral band?
1 nm - 50 nm, roughly corresponding to the region that is universally above all elements' lowest absorption edge, but still not energetic enough to penetrate hardly anything.
For such a 'neglected' brand it covers over Five Octaves ( ratio > 25) which is way bigger than the visible part of the spectrum. I was idly wondering about an application in Astronomy, say for estimating the density of nebulae material etc. by measuring the relative attenuation of wide band sources by spectrometry on the fringes of that band.
There's a fair amount of historical and biological accident in how we label the various ranges of the electromagnetic spectrum: for example, "infrared" and "ultraviolet" are only named categories because of how the human eye works, x-rays are their own category only because Roentgen observed them without knowing what they were (and again the history is in the name). And then terms like "soft x-ray" and "hard UV" evolved around those arbitrary starting points.
Clearly a more rational naming scheme could be devised. Establishing one in the face of long-established convention brings to mind the history of metrification.
Reply
  • Agree
RF communication uses band structure names which follows technology advances in devices and relates to the way electrons behave in various substances.
Some of the names were a bit fanciful. "Top Band" was just at the top end of MF frequencies; how little they knew!
