What Is the Next Number in This Mathematical Sequence?
  • Thread starter Thread starter cjbreen
    Sequence
The discussion centers around determining the next number in the sequence: 2, 3, 10, 15, 26, 35, 50. Participants converge on the conclusion that the next number is 63. Various methods are proposed to arrive at this solution. One method involves analyzing the differences between the numbers, which are 1, 7, 5, 11, 9, and 15. By segmenting these differences and applying arithmetic operations, a participant calculates that the next difference is 13, leading to the conclusion that 50 + 13 equals 63. Another participant shares a more complex approach involving a series of additions and subtractions that also results in 63, emphasizing the simplicity of their method despite their young age. Overall, the consensus is that 63 is the correct next number in the sequence, with multiple valid approaches to reach this conclusion.
cjbreen
What is the next number in the sequence? 2, 3, 10, 15, 26, 35, 50, ?
Is this some sort of homework question?
63
1st..(1*1)+1 odd
2nd (2*2)-1 even
3rd (3*3)+1 odd
8th (8*8)-1 even
yeah i got 63 too, but in a different way i think.
basically, the differences between them respectively, are 1, 7, 5, 11, 9, and 15.
divide it like this: 1, 7, 5, and 11, 9, 15
then take the sum of the last two digits in the first set, and subtract the first. so in this case, 7 + 5 -1.
you get 11, which is the next difference.
do this with the second set of 11, 9, and 15 and you'll get 13 as the next difference, meaning that 50 + 13 should be the next number.
that's how i got 63.
let me know what you guys think.
This is what I was thinking as well. I suspect it.anoopk's solution was probably the original intention. Seems a bit less random.
i got 63, too, but a different way, i got it by 2+1=3, add 6 to the one, 3:7=10, subtract 2 from the 7, add the number you grt<5> 15, add the 6 to 5 get 11 add 11 get 26 subtract 2 get 9 add 9 get 35 add 6 get 15 add 15 to 35 get 50 subtract 2 get 13 add 13 to 50 get 63 yay i win
i got it a different way: =2+1=3 add 6 to 1 get 7 add 7 get 10 subtract 2 get 5 add 5 get 15 add 6 get 11 add 11 get 26 subtract 2 get 9 add 9 get 35 add 6 get 15 add 15 get 50 subtract to add 13 get 63 =[] this is the immature way to do it but i got it done in 3 minutes and I am only 12...
that was too easy
10 10 11 12 15 16 21
S(n) = 2, 3, 10, 15, 26, 35, 50, 63, ... , (n2) - (-1)n
T(n) = (n2) - (-1)n
  • · Replies 17 ·
