Nobody understands quantum physics?
278 replies · 19K views
gentzen said:
Bell-tests are often arranged in a way that depending on some random element, something macroscopically different is done. This would be reflected in a time dependent Hamiltonian, if the used quantum description were "sufficiently complete". But since the outcome of this random element will be known in the analysis of the measurement results, it is unclear whether saying that the Hamiltonian was random makes physical sense.
Yeah that's true actually. You have similar measurement controlled gates in quantum computing. As you mentioned you never need to model them with randomised Hamiltonians. Such randomised Hamiltonians could always be absorbed into a CPTP map, just as randomised PVMs can just be represented as POVMs.
This gets fuzzy now but here I see a big problem. This "solution" of requires more complexity for representation and computation. If you rather are working from the perspective of a given generaliszed agent/observer i think there must be an effective cutoff due to information complexity which simply forbids going higher. I think this is not a solution that satisfies me becausa its like inventing an algorithm to solve a problem but no actual computer can execute it in relevant time scales. Such a solution, is no real solution.
/Fredrik
It's pretty routine in Quantum Information to write down POVMs and CPTP maps, I'm not sure what you mean.
vanhees71 said:
Where does the fundamental formulation of QT depend on classical physics?
WernerQH said:
Can you refer to a formulation of quantum theory that does not use the term "measurement"? And doesn't measurement require classical apparatus?
@vanhees71, what's your answer?
Yes I know, it was reflecting upon that from a foundational perspective with unification of forces in mind. If we stick to effective theories, there is not problem at all with your suggestion.
/Fredrik
My answer is that I don't see, where the problem is. The classical behavior of macroscopic matter, including matter used for measurements, can be understood from quantum many-body theory. On the other hand all experiments so far don't show any hint that macroscopic bodies don't show "quantum behavior" if I can prepare them in a state, where I can observe it, and indeed even the LIGO mirrors show quantum behavior, because one can measure their motion accurately enough to resolve it, btw. using again quantum effects to achieve this (squeezed states of light).
Shouldn't the teaching of quantum theory then start with QFT, as the basis? :wink:
Why does the formulation of quantum theory require such anthropocentric notions like "state preparation" and "measurement"?
https://www.physicsforums.com/insights/the-7-basic-rules-of-quantum-mechanics/
Do you consider it a waste of time (of "merely" philosophical interest) to search for a better formulation of the theory?
Quantum Theory says that not all physical quantities take well-defined values at all times, interactions with atomic systems are inherently probabilistic and the acquisition of information fundamentally disturbs the system. The conjunction of all these facts as can be seen in results like the Kochen-Specker theorem means you just can't talk meaningfully about "the well-defined quantities that hold values at all times independent of preparation and measurement".
It was an idealisation of classical mechanics where information could be obtained without disturbing a system, determinism held and all physical values were well-defined that you could divorce the theory from preparation and measurement*.
*Of course even here practically you couldn't, since physics always involves preparing a system and gathering the statistics for measurements. It was simply consistent with the theory to imagine doing so in some idealised limit.
From a strictly deductive approach you should start from a theory of everything and then derive the phenomena from the appropriate approximations for the given situation. That's of course impractical to introduce physics students to the subject ;-)).
All of physics requires the anthropocentric notions like "state preparation" and "measurement", because physics has estabilished itself as a description of the phenomena in quantitative terms, i.e., you must define in some way, how to measure things, including the definition of units etc. Only then can you specify the "state of the system" at some initial time ("preparation") in a concise quantitative way and measure properties of the system in a concise quantitative way at a later time ("measurement of observables"), and this is not different in classical physics too. So quantum theory is not more anthropocentric than classical physics.
For me, certain aspects of "measurement" are very hard (impossible?) to disentangle from anthropocentric notions. How can you formulate "no signaling" without reference to some human or agent like entity? And "randomness" is not much better, especially since it is closely related to "no signaling" in the context of QM.
For me, even so "state preparation" involves at least some knowledge about the state of some system, I don't worry too much about that being anthropocentric. The system will be in some state near the ground state anyway, whether some human or agent knows it or not (or even ensured it to a certain extent).
I think the confusion comes in because in Classical Physics you can imagine a limit of preparations that fix all future measurements. It's just like how Classical Probability allows you to imagine probability as ignorance of a "totally fine grained" state where all quantities are well-defined and there is no stochasticity.
I agree that practically Classical Physics is no different, but people tend not to think of Classical Mechanics in this practical way.
The reason is, that for classical mechanics (and also classical electrodynamics) nobody had the idea to have philsophical debates about them within the physics community. This sin was committed by Bohr, Heisenberg, and some other followers, and thus you have all this confusion about the most successful physical theory that has been discovered today. Another psychological phenomenon is that popular-science writers seem to think (maybe rightfully so) that their books sell better when claiming it's some mystery.
I'll never forget that, when I once went to a book shop (and it was also a university bookshop, not only a general one!) asking for quantum-theory books. The friendly clerk pointed right away to the "esoterics corner" and indeed, there was some pop-sci book about quantum mechanics (I think something like "The tao of physics"
https://en.wikipedia.org/wiki/The_Tao_of_Physics
Well, indeed, it was sorted in the right category, but it was definitely not, what I was looking for ;-).
  • Sad
Not that it matters, but historically speaking I wouldn't necessarily agree. Back in the 19th Century there were plenty of philosophical debates about electromagnetism, even Newtonian Mechanics and Gravity. Similarly for General Relativity with things like the "hole argument". And it was physicists themselves that were having these discussions.
I think it's that quantum theory violates our intuition more strongly, so these debates haven't died off as rapidly.
Well, yes, the hole argument was part of Einstein's struggle with the meaning of general covariance during the 10 years of research to find the final version of GR.
Indeed you are right, one of the greatest obstacles for the acceptance of GR was the inability of philosophers to understand it. That's most probably, why ironically Einstein is one of the few Nobel laureat's whose Nobel certificate explicitly states the very subject he has NOT gotten the prize ;-). It's pretty clear that Bergson's influence is the reason for that.
There's also a shift in the attitude to mathematics. Go back to the 30s and 40s and a non-mathematical discursive explanation of a theory was considered primary. The mathematics was simply how one implemented these ideas for quantitative use. I was surprised to find out even somebody as mathematical as Dirac thought this way.
The idea that mathematics was the primary way to explain physics only started to become common later. This is why older authors tend to have, from our perspective, rambling non-mathematical essays to explain things.
For me, this is just rationalization. Without realizing it, like so many physicists you have fallen victim to Bohr's tranquilizing philosophy ("Beruhigungsphilosophie", as Einstein put it). It's probably pointless to continue the discussion, if you refuse to even consider the possibility of a deeper understanding of quantum theory. Bell's qualms about the theory proved to be remarkably fertile, even leading to a kind of quantum information "industry", as you yourself have admitted. In his essay "Against Measurement" Bell argued that the axioms of such a fundamental theory should be formulated without vague notions like "measurement" or "system". But if you believe there is no better way, then nothing will convince you.
John Mcrain said:
Listen just 1 minute, what does it mean when he said nobody understand quantum mechanics?
This sound like comedy
I often differentiate between being able to do the math and having a good "feel" for what is going on.
As a programmer, I can take some formulae, code them up, test them, and be on my way without "understanding" anything about them.
More satisfying is to have a picture in my head about what is going on - a picture that guides me in broadening or extending the equations that I started with. With programming, it allows me to come up with more creative test cases. This picture probably comes from a combination of the genetics of my mentality and all those trivial experiments I performed with throwing balls, falling down, and playing with my food in my earliest years.
QM doesn't lend itself to that kind of "understanding". Particles do not move like play toys. When a ball is thrown, not only does it have a starting point and a ending point, but an entire trajectory. It is always somewhere - somewhere very specific. In QM, that is a failing model. Saying that the particle "travels" is simply borrowing an available term from our language. When the photon hits the screen in the double-slit experiment, it is as though the that photon has already tested the entire slitted barrier, treated it as a hologram, worked out the entire Fourier Transform to determine what its options are, then finally generated random values to supplement the constraints of Heisenberg Uncertainty.
We can know what it's doing. We can work through the numbers. We can fully simulate the process. But it's non-trivial to create a working mental picture that follows the process as closely as we do with a tossed ball.
Once you do get a good picture, it will not be reinforced by your daily experiences. Unless you are working with other Quantum Physicists, the language to describe it will not be exercised in your daily social dialogs.
And really, when it comes to QM experiments, by my measure, the double-slit experiment isn't the worse. If you move on to the Bell inequality, you should be able to fully understand the "paradox". But then to go beyond the arithmetic and "understand" the underlying process requires you to pick your favorite way to move information around in ways that you have innately trained yourself to take as impossible.
Such a concept wouldn't make much sense.
In QM you have your algebra of observables and then per Gleason's theorem (or Busch's if you take POVMs) quantum states, i.e. statistical operators, can be derived as probability assignments to the observables.
Thus they do take values probabilistically, but having the operator itself be random wouldn't make much physical sense. In a lab we know if we are measuring ##S_{x}## or ##S_{z}##, based on the orientation of the Stern-Gerlach magnets for example, that doesn't fluctuate.
But within a "real" lab (i.e. not an idealized thought experiment) you don't really know if you're measuring ##\hat S_x## or ##\hat S_{x+\eta}##, where ##\eta## is some (presumably random) perturbation within experimental error.
Couchyam said:
But within a "real" lab (i.e. not an idealized thought experiment) you don't really know if you're measuring ##\hat S_x## or ##\hat S_{x+\eta}##, where ##\eta## is some perturbation within experimental error.
That's handled with POVM tomography though, not randomised observables.
Simulate the process: yes. Know what "it" is doing: no. The picture of "something" that travels through the double slit is a mental image of overwhelming power. How else to explain what is going on in the experiments? But decades of brooding about the nature of photons have only produced abstract formalism. What we can most likely agree on is that there is a short "jiggling" of an electron at the source, followed a few nanoseconds later by a similar short jiggling of another electron a few meters away. QED lets us calculate the probabilities of such patterns of events. Our intuition misleads us to imagine something that "travels" from the source to the detectors. I think we should be less ambitious about "explaining" the correlations between events, and view QED as a theory that just describes the patterns of events that are scattered on the canvas of spacetime.
Any experiment must account for the possibility of noise and experimental error. You might devise some way to use POVM tomography to constrain the distribution of ##\eta##, but at the end of the day there will always be some statistical uncertainty.
That's incorporated into the POVM.
To my knowledge, POVM stands for "Projection Operator Valued Measure." Is the measure normalized to a particular number in the type of POVM that you have in mind?
But particularly Bell's work shows that standard QT is all there is. There's no realism, i.e. there's precisely the randomness about the outcome of measurements that's observed in the many Bell tests based on Bell's work. For me physics is about what can be objectively observed and described by mathematical theories. Since QT does this with great accuracy I indeed don't know what's still to be "deeper understood". It's not Beruhigungsphilosophie but simply the best description of the empirical facts.
What's really not yet understood is quantum gravity, but that's a scientific and not a philosophical problem.
POVM=positive operator valued measure. It's a more general descriptions of measurements that are not von Neumann filter measurements described by projection operators, PVMs=projection-valued measures.
And... are they typically normalized to something?
They sum up to the identity operator.
https://en.wikipedia.org/wiki/POVM
As per Naimark's dilation theorem one can explain the POVM from a PVM in a larger space. This in itself is easy to see, as it gives a distribution based on "ignorance" of some of hte reduced information. Also there is no conceptual problem here as long as we stick to sub atomicphysics. Ie. a dominant obsering context with a small quantum system.
My objection was that what is the agent can't encode this larger space? The usual thinking doesn't consider the explicit context, you can just imagine enlarging the hilbert space, mathematically, as you don't care about the context. It's just math! The "problem" does not lie in math, but the information processing of the implied information, and where this "physically" takes place, in the system, or in the environment, or where? In particle physics we know the answer, the application of QFT means all information processing are taking place in the classical environment, in the lab. And then none of my points make any sense! But if one start to picture including cosmological perspectives, where the observer is not surrounding a atomic scale the collision domain, but on the contrary immersed in the system of inquiry, then the method of enlarging the hilbert space becomes problematic to me at least.
The difference in relative size between the parts on each heisenberg cut seems critical to me. It's only when the observing side is dominant, that the effective classical reference is in place, and this is also when QFT as it stands indeed makes sense. Here it is also not necessary to worrt about "where information is processes" as the environment is so dominant that we can in principled do whatever we want and not be limited by computational speed or memory - until we start to speak about black holes (and include gravity).
/Fredrik
A POVM is fairly mundane stuff. One doesn't need to talk about cosmology, black holes, Heisenberg cuts or anything else. A POVM models measurements that have errors, thermal noise, false positives, dark counts, indirect measurements via coupling to an ancilla and so on. It's just as vanhees71 has above, a more general description of measurements than PVMs.
Thus regarding Couchyam's earlier statement, we don't need to consider randomised operators when discussing imprecise, noisy, etc measurements. We just use POVMs.
I agree.
My own take is that quantum theory was mostly sorted out conceptually by 1935. Heisenberg formulated the beginnings of the theory in 1925, but there were several conceptual points to be cleared up. These include details like the Mott paper on how lines observed in a bubble chamber were compatible with wave mechanics, von Neumann putting the theory on a sound mathematical footing, entanglement being first articulated, properly understanding scattering theory, that variables not commuting was not simply "disturbance" and so on.
What wasn't fully appreciated by 1935 were the deeper uses that could be made of entanglement and why the collective coordinates of macroscopic bodies, e.g. positions of planets, motion of a car, obey classical probability theory.
Entanglement has since been much better understood. For the latter we can now show how coarse-graining, decoherence, the exponential size of the Hilbert space and many other effects dampen coherence for macro-coordinates for a typical large object well beyond an inverse googleplex in magnitude.
Had there really been other problems they would have shown up in formulating QFT. The actual issues there however were completely separate: correctly formulating the Poincaré group for Hilbert spaces, renormalisation, the relation between particles and fields, treating couplings to massless states (i.e. gauge theories).
I think what @Fra was alluding to is that a POVM is more clearly relevant to open quantum systems whose dynamics are induced by a larger 'coherent' quantum system (although I may have misinterpreted Fra's comment.) A POVM can always be expanded into a PVM theoretically, but practically there's a limit to the complexity of the Hilbert space of a typical laboratory or experimenter, and thus there may be some POVM's (for some especially complex systems) that cannot be expanded into a controlled, laboratory-friendly, bona fide PVM (although a PVM may still exist in principle.)
I think I've found the source of confusion. My example of measuring ##S_{\hat x}## versus ##S_{\hat x+\eta}## may have been misleading, because from a purely quantum mechanical perspective, the randomness in any measurement could just be absorbed either by the state information itself, or the way in which the chosen observables partition state space (i.e. the POVM might not be a PVM.)
There is an important point to observe, however, which is very very loosely sort of related to how a thermal average is different from a quenched average in statistical mechanics. It's that at the end of the day, in a Stern Gerlach style apparatus, there is a definite classical direction ##\hat x+\vec\eta## to the magnetic field that deflects the beam, and that direction needn't change (randomly) between trials; in fact, it would probably remain approximately constant throughout the experiment. The perturbation ##\vec\eta## is determined when the experiment is set up, and might even change over time depending on how rambunctious the undergraduates are, and the difference between ##\hat x+\vec\eta## and ##\hat x## might not be explicable through an appropriate POVM. Similarly, the actual Hamiltonian of a particular experimental realization might differ slightly from the idealized theoretical version (two fields that are supposed to be perpendicular might be slightly aligned in a particular experimental setup, etc.) Does that partially clarify where I was coming from?
Does it? Hasn't it widened the field (quantum cryptography, quantum "teleportation", quantum computing)?
My conclusion is the exact opposite. I'd rather give up the "sacred" locality than realism. For me, realism means accepting the results of experiments as real; it does not mean we have to believe in the existence of photons with definite polarization states.
I agree that we are in the possession of a very good description, but I doubt that we have found the best formulation. Obviously you can't conceive of the possibility that quantum theory (after almost a century!) may be in a situation similar to that of electrodynamics before 1905.
