NonHomogeneous Second Order using Undetermined Coefficients
The discussion focuses on solving non-homogeneous second-order differential equations using the method of undetermined coefficients. The specific equation analyzed is y'' - 2y' - 3y = -3te^{-t}. The user correctly identifies the homogeneous solution as y(t) = c1e^{-t} + c2e^{3t} with roots 3 and -1. To find the particular solution, it is essential to modify the form of the guess due to the presence of e^{-t} in the homogeneous solution, leading to the suggestion of using y_{p}(t) = (At + B)e^{-t} to avoid duplication.
  • Understanding of second-order differential equations
  • Familiarity with the method of undetermined coefficients
  • Knowledge of homogeneous and particular solutions
  • Basic calculus and differential equations terminology
  • Study the method of undetermined coefficients in detail
  • Learn about the variation of parameters for solving differential equations
  • Explore the textbook "Elementary Differential Equations" by Boyce and DiPrima
  • Practice solving non-homogeneous equations with products of functions
Students and professionals in mathematics, engineering, and physics who are working with differential equations, particularly those seeking to deepen their understanding of non-homogeneous second-order equations.
Lucci
Hi all,
I understand the basic concept of undetermined coefficients, but am a little lost when g(t) in the equation yll+p(t)yl+q(t)y=g(t) is a product of two functions. The specific problem I'm working on is as follows:
yll-2yl-3y=-3te-t
When I solve for the homogeneous set of solutions I get roots 3 and -1
(r2-2r-3)=0
(r-3)(r+1)=0
Therefore, I have y(t)=c1e-t+c2e3t
Now, if g(t) were just equal to -3e-t I would just set Y(t)=Ae-t and use Y(t) to solve for the particular solution.
However, because g(t) is the product of two equations, I am not sure how to proceed at this point. Someone suggested that I use the homogeneous set of solutions as my Y(t), solve for Yl(t) and Yll(t) and plug those back into my original equation. Is this the correct way to approach this problem? And if so, how exactly am I supposed to do this?
Thanks for any help!
Hey,
For your particular solution, normally you would use
y_{p}(x)=(At+B)e^{-t}
where A and B are to be determined. However, e^{-t} is a term in the homogeneous solution so you need to multiply the particular solution by t so that the problem is fixed. You then plug it into the equation and proceed as normally.
Hope that helps!
Also, Boyce and DiPrima gives a nice discussion of this stuff! ^_^
  • · Replies 16 ·
