Northern lights and the magnetic field
The discussion centers on the relationship between the Earth's magnetic field and the morphology of the aurora borealis. Participants agree that the auroras result from collisions between solar wind particles and atmospheric molecules, particularly oxygen. The Earth's magnetic field is dynamic, influenced by solar flares and coronal holes, which cause geomagnetic storms. Rapid movements in auroras are attributed to Alfven wave structures in the upper ionosphere, rather than direct visualization of the magnetic field itself.
  • Understanding of solar wind dynamics and its interaction with the Earth's atmosphere.
  • Knowledge of geomagnetic storms and their causes, including solar flares and coronal holes.
  • Familiarity with Alfven wave structures and their effects in the ionosphere.
  • Basic concepts of atmospheric physics, particularly regarding molecular collisions.
  • Research the mechanisms of solar flares and their impact on geomagnetic storms.
  • Study Alfven waves and their role in auroral dynamics.
  • Explore the effects of coronal mass ejections (CMEs) on Earth's magnetic field.
  • Investigate recent publications on auroral phenomena using Google Scholar.
Astronomers, atmospheric scientists, and educators interested in the physics of auroras and the interactions between solar activity and Earth's magnetic field.
windy miller
When we see the aurora moving rapidly are we effectively seeing the Earths Magnetic field moving ? Is that part of the explanation for the morphology of the aurora and why they never look quite the same?
Astronomy news on Phys.org
I believe the particles are different. They enter the atmosphere at different velocity and from various angles.
The Earth's magnetic field is not static unchanging, and the solar wind is not either.
So its a combination of both ?
My understanding is that what you are seeing is collisions between oxygen molecules in the atmosphere and electrons and ions from a solar flair. What causes the pattern rather than just a random set of static like you would logically get I can not answer. Magnetism makes sense to me, since it mostly happens near the poles of the earth.
The auroras come about from the collision of the solar wind with molecules in the atmosphere. The movement comes mostly from where the stream of solar wind particle hits. The aurora is not a direct visualisation of the Earth's magnetic field.
Source: https://www.sciencelearn.org.nz/images/247-solar-wind-plasma-and-the-magnetosphere
Yes
Exactly, and this is particularly true when there are strong blasts of charged particles from the sun. The 2 main sources of these intense bursts of particles are from solar flares ( @thisisweak ) and from coronal holes.
The Solar wind is constantly spewing material into the surrounding space and in those conditions normally doesn't produce visible aurorae ( around the north and south poles) tho there can be weak radio aurora.
Coronal holes can produce minor to moderate geomagnetic storms. It's the significant solar flares M5 +++ with associated CME's ( Coronal Mass Ejections) that produce the moderate to major geomagnetic storms.
All significant pulses of particles from the sun cause the Earth's magnetic field to "flex" as those waves of particles push against it. and this is the main reason we see the waving motion in the auroral curtain.
Dave
There are a number of different types of aurora, and the causes are still a very active area of research. A number of models have been proposed, and a fair amount of data has been collected as well. One of the challenges for gaining understanding is that we are lucky when we have even one spacecraft in the right place at the right time to measure what is going on above interesting auroral features that we see from the ground.
Some of the more rapid, small-scale dynamics of discrete auroral forms are often attributed to Alfven wave structures in the upper ionosphere (above 1000 km, say). These waves can have electric field components parallel to the geomagnetic field so can accelerate the electrons towards the Earth. The dynamics of the waves (incident from above) as they reflect from the upper ionosphere and/or interfere with each other and/or breakup due to instabilities can be complex. In this model the rapid change in the auroral arcs are a consequence of the parallel electric fields associated with those wave structures, not rapid movement of geomagnetic field lines. There have been measurements, including quite recently, of these kinds of wave structures above the aurora. The temporal and spatial scales associated with the waves correspond with relevant scales of auroral forms, and numerical simulations of these kinds of wave structures are also consistent.
Other types of observed auroral structures, such as auroral spirals, may be due to instabilities associated with the thin current sheets of downward-moving electrons. Some of the instabilities could create vortex-street like structures ("spirals") that you also see in other types of fluid motion.
I'm sure there are a number of other mechanisms as well, but I am not an expert in this field so don't know what-all is known. If you do a search on google scholar you should find many publications on this topic.
Jason
  • · Replies 30 ·
  • · Replies 20 ·
