Number of combinations of marbles in a bag
  • Thread starter Thread starter moonbase
    Combinations
The discussion revolves around calculating the number of permutations for removing 10 marbles of different colors from a bag, emphasizing that the problem is about permutations, not combinations. The initial confusion stems from the wording of the problem, which incorrectly uses "combinations" when order is significant. The correct approach involves recognizing that if all marbles were distinct, the total arrangements would be 10!. However, since there are identical marbles, the formula to find the permutations is 10! divided by the factorial of the counts of each color, leading to the final answer of 12,600. This method effectively accounts for the indistinguishability of the marbles.
moonbase
EDITED: Should be permutations not combinations
You have a bag of 10 marbles. There are 4 red marbles, 3 yellow, 2 green, and 1 blue marble. You remove them from the bag one of the time without replacement. Assuming each color of marble is identical and it doesn't matter which specific marble of each color is chosen, calculate the number of possible permutations in which you can remove the 10 marbles.
If the specific marble picked did matter, the answer would be 10! but I'm not sure how to apply the different odds of the colors.
I found the number of possible colors that can be picked for each draw.
1st: 4
2nd: 3, 4
3rd: 3, 4
4th: 2, 3, 4
5th: 2, 3
6th: 2, 3
7th: 1, 2, 3
8th: 1, 2
9th: 1, 2
10th: 1
Then I multiplied every possible value: (4*4)*(3*6)*(2*6)*(1*4)=13824
Am I doing this wrong? And is there a more efficient way to figure it out?
Hi moonbase,
This is a poorly stated problem since it asks to "calculate the number of possible combinations in which you can remove the 10 marbles". In this sort of mathematics, "combinations" means an arrangement in which order does not matter. So if you believe "combinations" is being used in its proper sense, the answer is 1: the combination consisting of 4 reds, 3 yellows, 2 greens, and 1 blue. But I think that's not what is intended; I think the order is supposed to matter.
So assuming the order is significant, my suggestion is to start by asking how many arrangements there would be if all 10 marbles were considered different. Then maybe you can find a way to compensate for the colors.
You first try is not correct. It might be made to work, but's tricky because the decisions you make at one point (for example, is the first marble blue?) affect the number of choices later on, and it would take a lot of book-keeping to keep everything straight.
Oh okay I put the problem up from memory but I messed up the wording a bit. Anyway, I already know 10! is what it would be if they were all considered different, but I really have no idea where to go from there. Though I did realize this:
10 ncr 1 = 10
10 ncr 2 = 45
10 ncr 3 = 120
10 ncr 4 = 210
The sum of these is 385 but I don't think that's the correct answer because the possibilities overlap everywhere. Any other tips?
Nicely stated !
10 ncr 1 = 10
10 ncr 2 = 45
10 ncr 3 = 120
10 ncr 4 = 210
OK, so the total number of arrangements is 10! if all the marbles are different. Now let's suppose that just two of the marbles are the same color, like the two green marbles, and all the others are different. Label the two green marbles G_1 and G_2. In half the 10! arrangements, G_1 and G_2 appear in that order; in the other half, they appear in the order G_2 and G_1. So we if consider G_1 and G_2 indistinguishable, there will be 10! / 2 total arrangements.
Think about what would happen if there were 3 green marbles, G_1, G_2 and G_3. How many orders could they appear in? What would this do to the original 10! arrangements if they were indistinguishable? If you figure this out, then you should be able to extend the method to more colors pretty easily.
Okay so it would be 10!/(1!2!3!4!)=12600. Thanks!
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
