How Many Total Moles Are in a 1 Mol dm-3 Solution of HCl?
  • Context: Chemistry
  • Thread starter Thread starter fluppocinonys
    Molecules Moles
The discussion centers on calculating the total number of moles in a solution, specifically focusing on 1 mol dm-3 of HCl. The correct approach involves understanding that the concentration (mol dm-3) indicates the number of moles per cubic decimeter. The total moles in a 1 mol dm-3 solution of HCl is 1 mole, while the moles of water in 1 liter (1000 cm3) is approximately 55.6 moles, leading to a total of 56.6 moles when combined. The discussion also clarifies that the concentration should not be summed with the moles of water, as concentration is a measure of molarity, not total amount.
  • Understanding of molarity and concentration (mol dm-3)
  • Basic knowledge of moles and molecular weight
  • Familiarity with unit conversions in chemistry
  • Concept of solution composition and its components
  • Study the concept of molarity and its applications in solution chemistry
  • Learn about calculating moles from concentration using the formula: moles = concentration × volume
  • Explore the differences between molarity and molality in solution preparation
  • Investigate the role of water as a solvent in various chemical reactions
Chemistry students, educators, and professionals involved in laboratory work or solution preparation will benefit from this discussion, particularly those focusing on solution concentration and mole calculations.
fluppocinonys
How many number of moles of molecules are there in 1 mol dm-3 of HCl?
Is it correct to find it this way?
Number of moles of HCl = 1 mol
Number of moles of H2O = 1000/18 = 55.6 mol
So, total number of moles = 55.6 + 1 = 56.6 molesIf i change the question of 3 mol dm-3 of HNO3,
Then the total number of moles of molecules will be
3+ 55.6 = 58.6 moles?
Thanks.
The general conversion is with ratios, not with sums.
If Y = cubic decimeters of substance, F = formula weight or molecular weight of sought substance, and Z = ratio of moles of sought substance to volume of sample in cubic decimeters, then molesOfSoughtSubstance = Z*Y.
Check the units carefully for that formula to see how it works. Notice you would not need "F" because it was not directly needed. You would possibly need the formula weight if you were interested in any relation between mass and moles, but in your examples, you already had number of moles of a sought compound in a given unit of volume.
fluppocinonys said:
1 mol dm-3 of HCl
I have no idea what you mean. mol dm-3 is a measure of concentration, not amount.
10K
