Number of objects distributed between four people
  • Thread starter Thread starter gruba
    Distributed
gruba
Four people are dealing the total amount of money, which is [itex]1000[/itex] monetary units in terms of [itex]100[/itex] monetary units. Count the number of ways for this distribution if:
[itex]1)[/itex] Every person doesn't have to get any money
[itex]2)[/itex] Every person will get at least [itex]100[/itex] monetary units
[itex]3)[/itex] First person will get at least [itex]500[/itex] m.u. and other three people at least [itex]100[/itex] m.u.
-Combinatorics
The problem doesn't state what is the maximum amount of money that each person can get.
Assuming that, in [itex]1)[/itex] every person will get the same amount ([itex]200[/itex] m.u.), the total number of counts would be the coefficient with [itex]x^{1000}[/itex] in [itex](1+x+...+x^{200})^4[/itex].
In [itex]2)[/itex], assuming that the maximum amount for every person is [itex]200[/itex] m.u, the total number of counts would be the coefficient with [itex]x^{1000}[/itex] in [itex](x^{100}+...+x^{200})^4[/itex].
In [itex]3)\Rightarrow x^{500}(x^{100}+...+x^{200})^3[/itex]
What do you think, how to solve this problem?
You can convert (2) and (3) into the same problem as (1) with a different total to be distributed, by doing something non-probabilistic before you start the random part. What might that non-probabilistic step be?BTW, your formula ##(1+x+...+x^{200})^4## doesn't need to be have such a huge number of terms. Since everything is done in multiples of 100mu, divide the amounts by 100mu before you start.
-Combinatorics
I found the wording of your problem confusing: if you mean that each person can receive 0 or 100 or 200 or ... (i,e, multiples of 100) then you should say that a bit more clearly. If that is what you mean, it would be much easier to let 100 m.u be a new monetary unit. Now the amount each person can receive is an integer number of these new units and we have a total of 10 new units for distribution.
Also, to clarify: in (3), do you mean (in these new units) that persons 2--4 get at least 1 in total, or that persons 2--4 will get at least 1 each?
gruba said:
Assuming that, in 1) every person will get the same amount (200 m.u.)
That would not be a good assumption. As I read it, the whole amount is to be divvied up, and there's no restriction on who gets what. Essentially, you have ten identical things to put in four (distinct) baskets.
