One-dimensional potential well problem
The discussion centers on the one-dimensional potential well problem, specifically analyzing a particle of mass in a potential defined by V(x) = infinity at x<0, V(x) = 0 for 0a, where Vo>0 and E PREREQUISITES
  • Quantum mechanics fundamentals
  • Understanding of potential wells and bound states
  • Complex number mathematics
  • Wavefunction continuity and boundary conditions
  • Study the Schrödinger equation for one-dimensional potential wells
  • Learn about complex exponentials in quantum mechanics
  • Explore the concept of wavefunction normalization
  • Investigate the implications of boundary conditions on wavefunctions
Students and professionals in physics, particularly those focusing on quantum mechanics, as well as educators seeking to clarify concepts related to potential wells and wavefunctions.
Ruddiger27
My head's melting right now, because I've been stuck on this for the past 6 hours.
There's a particle of mass moving in a potential well where
V(X)=0, 0<x<a
V(x)= Vo, x>a
Vo>0
E<Vo
I'm assuming that the wavefunction at x<0 is 0, since there's an infinite potential there. The energy inside the potential well is just the kinetic energy, =(Hk)^2/2m, where H=h/2pi, so the wavefunction should be of the form
psi= Aexp(-ikx )
Now outside the well, at x>a, the energy should be E= Vo-Ek because the particle is bound in the well. We then get psi=Bexp(-Tx), where T is k with (Vo-E) instead of E.
Am I wrong in assuming this? When I try to find the radius using
X^2 + y^2 = R^2, where x=k=a*sqrt(2mE)/H and y=ai*(sqrt(2m(Vo-E))/H
I get out a negative radius.
Please help me see what I've done wrong, I'm sure I've got the energy value on the finite potential side wrong, but I can't see how.
Haven't gone through your entire question to know if this is the only mistake, but I believe you made a mistake determining psi in the well.
When you solve the differential equation you should get a couple exponentials...something like
psi=A*exp(ikx)+B*exp(-ikx).
Remember these are complex exponentials so they don't blow up at infinity and you can't eliminate terms like with real exponentials.
Now your boundary conditions require that psi=0 for x</= 0, so plugging in 0 for x we get A+B=0, and hence A=-B, and psi is some sort of sine wave of the form
psi=A(exp(ikx)-exp(-ikx))
I haven't gone through the rest of your problem, and I'm not sure what radius you are referring to at the end.
The radius comes in when we look at the wavefunctions across x=a, where they should be continuous, so psi1=psi2 and dpsi1/dx=dpsi2/dx. I have to divide one by the other to get a solution in the form -y=xcot(x), then rearrange the circle equation to get y, sub it in and the intersection gives the solution.
Ok thanks, you've really helped me out, the website was especially helpful.
  • · Replies 20 ·
