Shooting a rifle at a target 40 m high and 1500 m away
  • Thread starter Thread starter taffman123
43 replies · 7K views
taffman123
hello - i am a first year university student and received an assignment last week - one question i am having very difficulty with is a question about shooting a rifle gun. the question is
If you wanted to shoot an objec on a building that is 40 m high and and 1500 m far with a velocity of V what would be the angle? is there anyone who can get me on the rigth track?
Hi, sorry posted in the other thread. How do you think you should start?
What kinematic equations do you know? Think about the horizontal component because now we have 1500m this is the easiest componet to calculate.
You must know some kinematic equations, [itex]v =u +at[/itex], for example.
i know 5 kinematic equations
but only 4 i can use because i do not know what v2 is
d = v1t + 1/2at^2 = that is the one i am primarily trying to use
and also i am thinking of using d=vt
So, what do you know and what do you need to know? Which equation(s) statisfy the criteria?
with having a d = 1500m
v = 854cosx
and an unknown time it seems easy - but for me i got confused with the cosx
would my time = 1.756cosx? or would it = 1.756/cosx?
[itex]d = vt[/itex] is the same as [itex]d = ut + \frac{1}{2} at^2[/itex] without any acceleration. Which is the case horizontally, therefore you can calculate the horizontal flight time as a function of [itex]\theta[/itex]
(y axis)
d = 40m
t=?
a=-9.8m/s
v1= 854sinx
makin my equation
40=854sinxt + -4.9t^2
Hootenanny said:
Your time would be [itex]t = \frac{1500}{\cos x}[/itex]
what happened to the v of 854?
so when i isolate for t (vertical) would it look like
2t =Square root of (40/854sinx) X 1/-4.9 ? or did i make an isolation mistake
I'm afraid you cannot isolate [itex]t[/itex], the equation is a quadratic.
thats what i tohught because i had a t + t^2 but i just thought if i brought the ^2 over it would be ok
No because only one term is squared, when you root both sides you will get [itex]t + \sqrt{t} = ...[/itex].
ok - so now my equation would look like
40/854sinx * 1/-4.9 = t + t^2 and now I am confused
the only thing i could do is substitute t = 1500/854cosx?
but having all these cosx and sinx in the equation is going to fustrate me so much
Yes, but I would suggest leaving it in the form [itex]854 \sin x t - 4.6t^2 - 40 = 0[/itex]
ok so i used the quadratic to solve f or t but in my square root i have sinx now i am totally confused
Try substituting in the [itex]t = \frac{1500}{854\cos x}[/itex]into the equation [itex]854 \sin x t - 4.6t^2 - 40 = 0[/itex] and using trig identities instead.
i have a question - and hopefully u will not be offended - i am not here for anyone to do it for me - but i was just wondering - have u figured out the answer?
No, I'm not offended but I haven't worked it through yet. I'm just telling you what I would do at each stage. I will work it through if you like though.
right now i am at the stage
1.756cosx - 15.1169cos^2x-40= 0
and now i am stuck again
but i did not use a trig idenity yet - so i migth have made a mistake?
i had
854sinx( 1500/854cosx)
so after multplying i had a sinx on top and bottom so they canceled out but the sinx was attached to cosx - am i still allowed to cancel it out
