Oscillations of Spring with Viscous Medium
17 replies · 2K views
robax25
A spring with K=12N/m and an attached bob oscillates in a viscous medium.Amplitude is 6cm from equilibrium position at 1.5 s and Next amplitude of 5.6 cm occurs at 2.5s. what is its displacement at 3s and 4.5s and t=0s
x(t)=Xme^-bt/2m
x=4.16cm
[/B]
e=0.133 as the ration of decay.
x(t)=xm x .133 and However, I am confused to find Xm(amplitude at 3 s) . I considered Xm=5.2cm at 3s. But, it is a false assumption.
That is not what scottdave asked. The x(t) expression should have a trigonometric factor to represent the oscillation.
I do not get it. How can I calculate trigonometric factor?
You know the period. What is the general formula for a damped oscillation?
x(t)=Xme^-bt/2m here Xm is amplitude, b is damping factor
So is Xm the amplitude of the cosine wave? Did you look at the hyperphysics link I sent?
I saw it ..they consider a for amplitude.However, I consider Xm
robax25 said:
x=4.16cm[/B]
“The attempt at a solution” means your steps and thoughts. Please show effort.
But clearly that does not produce an oscillation - unless that Xm is also a function of time.
What is the formula for an undamped SHM?
Undamped SHM x(t)=Xmcos(ωt+∅)
for damped Oscillation x(t)=A e^-bt/2m cos(ωt+Φ). I did not notice it properly
Here A is amplitude
Here A is amplitude
Right.
Now it is a matter of plugging the known facts into that equation to determine A, b/m, ω and φ.
So you need four equations. Knowing the displacement at a given time gives you one, and knowing that this is a local extrememum gives you another. You have that for two different times, giving you four equations altogether.
how can I get the position at 3s?
Once you have determined the four constants as I described in post #16, you plug t=3 into your equation in post #15.
