How to Perform Pairwise Comparisons with Limited Data?
  • Thread starter Thread starter amalak
To perform pairwise comparisons with limited data, transforming the data to meet normality requirements is a recommended strategy. If transformation is not feasible, Bayesian Inference can be utilized as an alternative to frequentist methods, especially for small sample sizes. The Bayesian approach allows for the extension of the paired t-test, accommodating prior information. Software like WinBUGS can facilitate this process by simulating models using MCMC, although it may be complex to implement. Exploring these methods can help determine the significance of area changes over the years.
amalak
Hi there,
If I have 5 numbers that represent the area of a forest from 5 separate years, is it possible to yield 4 pairwise comparisons? I would like to know if the change in area is significant from year to year, but cannot figure out which statistical test to use since I only have one measurement (the area) in each treatment (the year).
(Note: I've tried to justify using the z-test, t-test, and ANOVA, but I either cannot assume normality or have too few observations within each group.)
Any guidance would be much appreciated. Thank you in advance.
p.s. This is for my job, not for homework.
Hey amalak and welcome to the forums.
Have you considered a transformation of your data so that you can meet the normality requirements? This is a typical strategy to use when things don't meet the assumptions and you need to think about how you can take your data and transform it so that you can specific piece of statistical machinery.
In terms of statistical theory, the generalized form of inference is the Bayesian Inference and this is often used when the frequentist methods just don't cut it (especially good for small samples with some kind of expert or prior information).
I would firstly try to transform your data and if you absolutely need something for this, then you should read the Bayesian Inference and how you can extend the paired t-test to the Bayesian situation.
There is a program called WinBUGS which will take a model, simulate it using MCMC and you can use those distributions to get the mean and variance of the simulated distribution to use for hypothesis testing, but it's pretty complicated because of it's general nature.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
  • · Replies 20 ·
