- 16,335
- 258
Femme_physics said:Is "power dissipation" the power equivalent to "voltage drop"?
Yes.
I like Serena said:Let me see...
The voltage across the 5 ohm resistor is 31.58 V.
So the power dissipated in the 5 ohm resistor is... exactly what you wrote!
But... the 5 ohm resistor is not between A and B...
So no, you did not get it.
But the unit you deduced for the power looks very powerful indeed!![]()
gneill said:ILS, perhaps you should have specified the particular component (or components, or path) for which you wanted the power dissipation. Technically, ALL of the components are between nodes A and B, as there is are paths that will take you from A to B through all of them.
Femme_physics said:
Ah, I see the errors of my ways
I know what to do! *rubs hang together in an evil fashion*
Let me find Ptotal first. Then I shall have the answer, and all the smurfs will be mine!
((PS. Rtotal ends up being 6.33333 ohms ))
I intended to ask for the power dissipation in the 4 ohm resistor that is between A and B.
I give you the smurfs. All of them are yours, you *evil* you!
Btw, the total power is the sum of the powers dissipated in each of the 3 resistors.
Femme_physics said:Easy peasy!
P2 = 2 x 5.211^2 = 54.31 [W]
Muwahhaahahhah!
You mean
Pt = Power dissipated in resistor 1 +Power dissipated in resistor 2 + Power dissipated in resistor 3?
In which case, I was aware of that!
And I did get the correct result, yes?
I like Serena said:And here's a second one.
Perhaps you can start a separate thread for this problem?For the circuit shown below, determine the voltage for each of the
resistors and label the values on the diagram.
I like Serena said:How about this one?
[PLAIN]http://img25.imageshack.us/img25/4407/circuitj.jpg[/QUOTE]
First question--
How come they get to pick for me the direction of I? Shouldn't I be the one determining it?
Femme_physics said:First question--
I like Serena said:Not that. You made a mistake.
Perhaps I should have said that you dropped a smurf?
I like Serena said:Well...
Look at the drawing in your first post in this thread.
You did not mark the directions of the currents (and as a consequence you made a mistake with it).
So I thought I'd better mark them for you!
(Just kidding, I just picked the first exercise that fitted your description.)
The real reason would be that the people who made the exercise would want the same answer from all students, so it's easier for them to check the answers. This means naming the currents and preselecting the directions.
Femme_physics said:More like a typo! I've accidentally linked the wrong file
Femme_physics said:Interesting. So you get different answers if you pick different direction for I? I didn't know that!
Yep! You found the smurf! :)
If you pick the direction of a force in mechanics in the other direction, don't you get a different answer too?
I like Serena said:Sauron misplaced one small ring, that was picked up by one small guy.
He never thought it would matter, especially since not even the great white wizard (Saruman) could withstand his corrupting power. :)
(Both in the books and in the movies.)
