Parametric equations for geodesics
4 replies · 7K views
andybham
What are you trying to do when you find parametric equations for a geodesic lines on a surface?
Take the metric ds^2 = dq^2 + (sinh(q)*dp)^2
Are you simply trying to get q as a function of s? and p as a function of s?
If so, why?
Thanks
Clarifying meaning of geodesic equations
In the line element for the hyperbolic plane (this trig chart covers all but one point) which you wrote down,
[tex] ds^2 = dr^2 + \sinh(r)^2 \, d\phi^2, \;<br /> 0 < r < \infty, \; -\pi < \phi < \pi[/tex]
(I changed to a more suggestive notation), s is playing the role of arc length. The standard method of obtaining the geodesic equations is to read off what MTW call the "dynamical Lagrangian"
[tex]L = \dot{r}^2 + \sinh(r)^2 \, \dot{\phi}^2[/tex]
Then apply the Euler-Lagrange equations:
[tex]0 = \frac{\partial L}{\partial r} - \frac{d}{d s} \; \frac{\partial L}{\partial \dot{r}}, \; \;<br /> 0 = \frac{\partial L}{\partial \phi} - \frac{d}{d s} \; \frac{\partial L}{\partial \dot{\phi}}[/tex]
Simplify the result so that [itex]\ddot{r},\ddot{\phi}[/itex] are monic and collect terms in the first order derivatives. The result is the geodesic equations in their standard form and the coefficients are the Christoffel coefficients:
[tex] \ddot{r} + \sinh(r) \, \cosh(r) \, \dot{\phi}^2 = 0, \;<br /> \ddot{\phi} + 2 \, \coth(r) \, \dot{r} \, \dot{\phi} = 0[/tex]
where "dot" means differentiation wrt the parameter s. Here, s is playing the role of an arc length parameter, so the solutions of these equations give the geodesics as arc length parameterized curves. The second equation has a first integral
[tex]\dot{\phi} = \frac{L}{\sinh(r)^2}[/tex]
which is obviously similar to the analogous first integral for a radial chart for the Euclidean plane (substitute [itex]\sinh(r) \mapsto r[/itex] and consider what happens for small r).
Exercise: consider a simple semi-Riemannian analogue:
[tex] ds^2 = -dt^2 + \cosh(t)^2 \, d\phi^2, \;<br /> 0 < t < \infty, \; -\pi < \phi < \pi[/tex]
(This is the upper half of [itex]H^{1,1}[/itex], the hyperboloid of one sheet in [itex]E^{1,2}[/itex], the signature 1,1 manifold of constant curvature, aka "two-dimensional tachyonic momentum space".) Why do the resulting equations give all geodesics, including null geodesics, as affine-parameterized curves? (This point recently confused someone in another thread.)
Thankyou for your reply.
because we are optimising s hence finding the shortest path through space-time?
I have an example question (and the corresponding solution) for the metric I gave
that was used on a past exam paper.
I understand everything except the question asks 'find parametric equations for geodesic lines on this surface' and the solution produces
cosh(q) = cosh(q0)*cosh(s)
from the first integrals. SImilarly, it also gives
dp = (sinh(q0)*ds)/(cosh^2(q0)*cosh^2(s)-1) [I apologise, I don't know how to add tex code]
I understand the maths involved in getting these results, however, in order for me to be able to obtain similar expressions for different problems in the exam I need to understand what the question is asking when it says 'find parametric equations for geodesic lines on this surface'
If so, why?
The dynamic Lagrangian method automatically gives the geodesics in affine parameterization. It is the assumption that one has used an affine parameterization that allows the simple method of the dynamic Lagrangian to work.
Note that L is a quardratic form Q in the dynamic Lagrangian method
If you wish to find the geodesics in arbitrary coordinates directly, you must solve the Euler-Lagrange equations with L = sqrt(Q), rather than the Lagrangian given in the previous post by Chris Hillman which is specific to the dynamic Lagrangian method.
It is the simplification involved in getting rid of the square root (which is quite significant, if you actually go through the work of solving it) that makes the dynamic Lagrangian method attractive.
A very similar method is the Einbein method, which is usually used in other contexts than geodesics but also serves the function of getting rid of the square root in a Lagrangian.
See for instance:
https://www.physicsforums.com/showthread.php?t=127956
For a textbook discussion, if you happen to have MTW "Gravitation", pg 315-324 discuss both the direct method and the dynamic Lagrangian method.
Ah I see, the two equations provide the parametric representation of a typical geodesic.
Thankyou both for all your help!
