Partial Differentiation -- If w=x+y and s=(x^3)+xy+(y^3), find ๐w/๐s
The discussion revolves around the partial differentiation of two functions, \( w = x + y \) and \( s = x^3 + xy + y^3 \), with a focus on finding \( \frac{\partial w}{\partial s} \). Participants express confusion regarding the implications of holding certain variables constant during differentiation.
  • Participants explore the implications of implicit differentiation and question which variables are held constant during the differentiation process. There are attempts to clarify the relationship between \( s \), \( t \), \( x \), and \( y \), as well as discussions on how to approach the problem using chain rule concepts.
The discussion is ongoing, with various participants offering insights and questioning assumptions. Some suggest that the problem could be approached by differentiating the expressions for \( t \) and \( s \) with respect to \( s \), while others express uncertainty about the clarity of the original problem statement.
There is a noted lack of clarity in the problem setup, particularly regarding the relationships between the variables and the conditions under which partial derivatives are taken. Participants are attempting to navigate these ambiguities while discussing the implications of holding certain variables constant.
Robin64
๐w/๐s=(๐w/๐x)*(๐x/๐s)+(๐w/๐y)*(๐y/๐s)
๐w/๐x=1
and then I wasn't sure about ๐x/๐s, so I tried implicitly differentiating s:
1=(3x^2)(๐x/๐s)+y(๐x/๐s)+x(๐y/๐s)+(3y^2)(๐y/๐s)
And then I shaved my head in frustration.
If you are taking a partial derivative, what parameter is being held constant?
Is this the whole question, word for word? It doesn't make sense to me.
If s varies it is because x and or y varies, but a given change in s can be achieved by changes in x and y in different ways, and these lead to different changes in w.
I forgot this part of the question. Apologies: (x^2)*y+x(y^2)=t
Is ##dt=0 ##? i.e. is the partial derivative w.r.t. ## s ## at fixed ## t ##? You need to be more clear please.
This is all I know.
Robin64 said:
This is all I know.
It could have been made clearer in the question, but from the full text one can guess that the partial wrt s means t constant, and mutatis mutandis.
I apologize for that. Nothing else has flummoxed in calc, but whatever reason, this has done just that.
Are you ok to go ahead now?
Not really.
Robin64 said:
Not really.
What equation do you get if you ##\partial/\partial s## the equation for t?
Guys i don't understand why you interfere with ##t##. You can evaluate ##\frac{\partial x}{\partial s}## directly as $$\frac{\partial x}{\partial s}=\frac{1}{\frac{\partial s}{\partial x}}$$ you ll just find it as function of x and y instead of s and t.
Same logic applies to ##\frac{\partial y}{\partial s}##.
t is just t(x,y). I don't see how ๐t/๐s help me.
And frankly I don't see how to calculate ๐t/๐s
You can't do that with partials.
x=r cos(ฮธ)
##\partial x/\partial r=\cos(\theta)##
##r^2=x^2+y^2##
##\partial r/\partial x=2x##
The flaw is that something different is being held constant in the two cases.
alternatively (for the OP) you can set ## dt=0 ##.
x=r cos(ฮธ)
##r^2=x^2+y^2##
Yes you can. You have a mistake in the last line, you get that $$2r\frac{\partial r}{\partial x}=2x\Rightarrow\frac{\partial r}{\partial x}=\frac{x}{r}=\cos\theta$$
Oh sorry , should have prove that ##\frac{\partial r}{\partial x}=\frac{1}{\cos\theta}##, maybe you are right @haruspex .
When you say let dt=0, let the partial of t with respect to x plus the partial of t with respect to y=0?
Yes, that was careless, but as you saw the corrected version makes my point.
So if dt=0 then:
(2xy+y^2)dx+(2xy+x^2)dy=0...?
No, @Charles Link and I are saying the same thing in different ways. Differentiate the expression for t partially wrt s.
The key is that if there are two independent variables u and v then ##\frac{\partial f}{\partial u}## is shorthand for ##\frac{\partial f}{\partial u}|_{v}##, i.e. the change in f as u varies but v stays constant. In particular, ##\frac{\partial v}{\partial u}=0## by definition.
In my Cartesian/polar example, the partial derivative wrt x implicitly means holding y constant, whereas the partial wrt r means holding theta constant.
t isn't a function of s.
No matter.. ##\partial t/\partial s## means the change in t if s changes but t doesn't, i.e. 0.
It produces what you got in post #21 except that, usefully, you have ##\partial x/\partial s## in place of dx and ##\partial y/\partial s## in place of dy.
Ok, I see that.
then I solve for ๐x/๐s and ๐y/๐s?
So @haruspex, under suitable assumptions on what is being held constant (in your example if we keep ##\theta## constant) can we use the equation $$\frac{\partial x}{\partial s}=\frac{1}{\frac{\partial s}{\partial x}}$$
Adding to my confusion is this. The solution to the problem is below, and I have no idea how to get there. Can anyone provide more illumination? I looked for resources that describe the application of the chain rule to these types of partial derivatives, but I can find nothing. Boas' "Mathematical Methods in the Physical Sciences" is less than helpful. Is there a YouTube video or a book that better describes how to approach a problem such as this one?
In principle, you can differentiate both the expression for t and the expression for s partially wrt s to get two equations involving ๐x/๐s and ๐y/๐s, and hence solve for those. But it will get very messy.
A much easier way here is to rewrite the expression for s in terms of w and t, eliminating x and y. It takes a little ingenuity, but not much work.
If you elect to keep the same variable constant in both derivatives then you don't need partials at all. Just differentiate normally, but treating that variable as a constant.
E.g. if we set ฮธ to be constant and write y = x tan(ฮธ), we have ๐y/๐x = dy/dx = tan(ฮธ) and ๐x/๐y = dx/dy = cot(ฮธ).
Btw, the Cartesian/polar example can be viewed graphically. Draw a vector r and a corresponding vector x on the x axis. The partial derivative of one wrt the other is represented by the component of the one in the direction of the other. You can see that in each case you multiply by cos theta.
  • ยท Replies 18 ยท
  • ยท Replies 6 ยท
  • ยท Replies 2 ยท
  • ยท Replies 2 ยท
  • ยท Replies 6 ยท
  • ยท Replies 12 ยท
  • ยท Replies 2 ยท
  • ยท Replies 25 ยท
  • ยท Replies 10 ยท
  • ยท Replies 7 ยท
