"Partial Fractions" Decomposition Integrals
The discussion revolves around the topic of partial fractions, specifically focusing on the decomposition of integrals involving rational functions with polynomial denominators. The original poster presents an integral that includes a product of linear and quadratic factors.
  • The original poster attempts to decompose the given integral into simpler fractions but expresses confusion regarding the appropriate form of the numerator for the quadratic term. Participants discuss the necessity of using a polynomial of one degree less than the denominator and question the assumptions made about the coefficients in the numerator.
Participants are actively engaging with the original poster's approach, providing guidance on the correct form of the numerator for the quadratic term. There is a productive exchange of ideas, with some participants suggesting a more general form for the numerator to account for all possibilities. However, there is no explicit consensus reached on the final approach.
There is an indication that the original poster has limited experience with denominators raised to a power, which may affect their understanding of the decomposition process. The discussion also reflects varying interpretations of how to handle polynomial degrees in the context of partial fraction decomposition.
DameLight
Hello,
I was just introduced to this concept and I have solved a few problems, but I haven't come across any with denominators to a raised power yet.
∫ 1 / [(x+7)(x^2+4)] dx
I would appreciate any directed help.
1. from the initial state I have broken the fraction into two assuming that (x+7)(x^2+4) is the common denominator where A and B are unknown.
∫ A / (x+7) + B / (x^2+4)
B / (x^2+4) has me confused
as I said before, I have not come across denominators to a raised power before and understand that the numerator needs to be raised to one power less, but what this looks like I don't know.
The first part of your PF decomp, A / (x + 7), is OK. For the second part, B / (x2 + 4), you should assume the numerator is a polynomial one-degree lower than the denominator, which is why you assume A / (x + 7).
For the second part, instead of just B in the numerator, what should you assume?
Bx + B + 1?
DameLight said:
Bx + B + 1?
And why would you assume this?
because the polynomial on the bottom is in degrees of x so B ( x + 1 ) is better?
You're assuming that the coefficient of x and the constant will be the same. That's a bad assumption.
Make the numerator the more general Bx + C to cover all possibilities.
ah I see now thank you for your help : )
"In degrees of x"? Surely you meant to say "second degree in x"!
  • · Replies 16 ·
