Partial Fractions (Laplace Transform, complex roots)
The discussion focuses on the application of partial fractions in finding the inverse Laplace Transform, specifically when dealing with complex roots. Participants clarify that when determining constants in partial fractions, real and complex numbers should be treated separately. An example is provided using the function 1/(s^2 + 2s + 4), demonstrating the decomposition into A/(s + 1 - √3i) and B/(s + 1 + √3i). The method involves equating real and imaginary parts to derive equations for constants A and B.
  • Understanding of Laplace Transforms
  • Familiarity with complex numbers and their properties
  • Knowledge of partial fraction decomposition
  • Basic algebraic manipulation skills
  • Study the method of partial fraction decomposition in detail
  • Learn about the properties of complex numbers in mathematical analysis
  • Explore the application of Laplace Transforms in differential equations
  • Investigate the use of MATLAB or Python for computing inverse Laplace Transforms
Students and professionals in engineering, mathematics, and physics who are working with Laplace Transforms and require a solid understanding of complex analysis and partial fractions.
sandy.bridge
Hello all,
Say one wants to find the inverse Laplace Transform of a function, and the method for attaining the solution is executed via partial fractions. Do the real numbers go with the complex numbers when determining the constants of partials? Perhaps this is wordy. I'll provide a theoretical example:
Say we have:
\frac{A}{s+1-\sqrt{3}j}+\frac{B}{s+1+\sqrt{3}j} where A+B=s+2.
Do we say:
A(1+\sqrt{3}i)+B(1-\sqrt{3}i)=2
or are the complex numbers treated separately?
If you're trying to find the partial fraction decomposition of 1/(s^2 + 2s + 4), which is what i think you're doing here, you should get
\frac{A}{s + 1 - \sqrt{3} i} + \frac{B}{s + 1 + \sqrt{3} i} = \frac{1}{(s + 1 - \sqrt{3} i) (s + 1 + \sqrt{3} i)}
Multiply both sides by (s+1-sqrt(3)i)(s+1+sqrt(3)i) to get the right side as just 1. Then you'll have the real part of the left side equal to 1, and the imaginary part equal to 0. That should give you two equations for A and B.
A+ iB= C+ iD if and only if A= C and B= D.
  • · Replies 17 ·
