Path of object with equal constant accelerations in two dimensions
  • Thread starter Thread starter RoboNerd
    Acceleration Path
9 replies · 2K views · last reply
RoboNerd
If an object moves with non-zero, constant accelerations in two dimensions which are equal in magnitude, its path is
1) linear
2) hyperbolic
3) elliptical
4) parabolic
5) circular
no equations
apparently, the correct answer is 1. How is that even possible. Thanks in advance for the input.
Take an example...
Imagine an object starts from rest at the origin x,y = 0,0
Then it starts moving and accelerates at the same rate in x and y.
After time t, what will the x and y components of the displacement be?
x: 0.5 * acceleration in x direction * t^2
y: 0.5 * acceleration in y direction * t^2
Let Ax be the acceleration in the x direction
and Ay be the acceleration in the y direction
Let Ax=k1 ; Ay = k2
Integrate to get
Velocity
Vx = k1t + c1 ; Vy = k2t + c2
Again integrate to get
Position
Sx = (k1t^2)/2 + c1t + d1 -(I)
Sy= (k2t^2)/2 + c2t + d2 -(II)
Multiply (I) by k2 and (II) by k1
Then Subtract to get a linear relation between Sx and Sy.
@Sahil Kukreja, I see how your approach works, but this question is intended to be solved in a simple manner. I believe this method overcomplicates it. Is there any way to do this with some geometrical intuition?
Thanks!
acceleration in x direction = acceleration in y direction
So y = x which is a straight line.
I'm not sure I even understand the statement of the problem. I guess it means ax = ay = constant. But it doesn't say that the object starts at rest. It seems to me that you just have an object moving in 2 dimensions with a constant acceleration vector. Isn't the general motion parabolic, like projectile motion except the direction of the acceleration is not vertical?
Hi, Sahil.
This does not necessarily imply that the trajectory is linear because the relation still involves the time t explicitly.
Suppose y = ax + t where a is a constant and y and x are functions of time t. At time t1, the point (x,y) will lie on the line y = ax + t1. At time t2, (x,y) will lie on a different line y = ax + t2.
Perhaps the RoboNerd can confirm that the problem statement is exactly as written in the OP?
It does look like there is something missing.
TSny said:
Hi, Sahil.
yes i think you are correct.
