PCAT Variance Qs: Range of Scores & Similar Mean Values?
  • Context: Undergrad
  • Thread starter Thread starter mohamma1
    Studying
The discussion revolves around understanding variance in the context of the PCAT, specifically addressing how to compare variation between different data groups using range and standard deviation. Participants express concerns about the simplification of variance concepts in practice questions and seek guidance on effective methods for assessing variance visually or through calculation.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • Some participants question whether using the range of scores is a sufficient method for comparing variation between data groups, suggesting that similar mean values might be a prerequisite.
  • There is a concern about the terminology used in the PCAT practice questions, with participants arguing that the term "variation" is confusing and that variance should be clearly defined as a formal calculation.
  • Some participants express frustration over the reliance on potentially misleading terminology in official practice materials, emphasizing the need for clarity in definitions.
  • Participants discuss the difficulty of judging variance visually and suggest that while inspecting data point dispersion might provide some insight, it ultimately requires calculation for accuracy.
Participants generally agree on the confusion surrounding the terminology used in the PCAT practice questions and the need for clearer definitions. However, there is no consensus on the effectiveness of using range as a rule of thumb for comparing variance, as some believe it may not be adequate without additional context.
Participants note that the practice questions are based on older exams, which raises concerns about their reliability. There is also an acknowledgment that visual inspection of data may not effectively account for outliers or provide a definitive measure of variance.
Students preparing for the PCAT, educators teaching statistics, and individuals interested in understanding variance and its implications in data analysis.
mohamma1
I'm studying for the PCAT and have come across a few variance questions. I feel like they are just oversimplying the heck out variance. I'll post one of the latest questions ...
[PLAIN]http://img825.imageshack.us/img825/1875/32561537.jpg
The explanation they give is because Class A has a larger range of scores (19 vs. 17) it "suggests" that the variation is greater. I really don't think they want me to find the expected value and then subtract each score from that and then square it and w/e else to find the exact variance. So is just looking at a range of scores a decent rule of thumb to compare variation between different data groups? Or would I need some pre-req like they atleast need to have similar mean values?
I don't like the terminology used in this example. It is confusing. Variance ([tex]SD^2[/tex]) is a formal, well defined calculation. Range is not used that much in statistics but it's understood to be the difference between the extreme values of a sample. To lump them into a single term "variation" is a bad idea IMO.
In the example A obviously has the greater range and B the greater SD. Why confuse people with a term like "variation". At least a definition of someone's idea of what "variation" is should be provided.
Yea, I completely agree. The worse part is this is an official PCAT practice, and they say 80% of the questions were on old exams so I'd be screwed if it was on the real test. Are there any good general rules I can use to find variance by just look at a set of data or graph.
mohamma1 said:
Yea, I completely agree. The worse part is this is an official PCAT practice, and they say 80% of the questions were on old exams. Are they are good general rules I can use to find variance by just look at a set of data or graph.
In comparing two samples can you sometimes judge which sample has the larger variance by inspecting the data point dispersion. Otherwise you just have to calculate it. It's also difficult to judge the effect of outliers just by inspection. If you look at data point printouts enough you get a feel for it, but there's no general rule other than calculating it IMO.
