Permutation of subsets with like objects Question
2 replies · 4K views · last reply
Astro
Permutations of subsets with like objects Question
Hello, I'd like to know if I solved the question correctly; if not, I'd appreciate some help.
Question:
Calculate the number of permutations for a subset of 3 objects from a superset of 8 objects where 5 are alike.
My solution attempt: (Please see attachment).
  • Handwritten solution attempt on lined paper titled 'My Solution Attempt', counting permutations of 3 objects from 8 with 5 alike, with a second page showing the answer 236 and the question 'So is correct?'
Your solution is fine except for the factors like C(5,2). This looks like you are counting the ways of picking 2 objects from 5 identical objects. That's not C(5,2). It's 1.
Thank you, you're input helped! I believe the answer is 106, not 196. I was going to post a detailed and neat explanation of how I got 196 but I'm so busy that I can't (which is why it took so long for me to reply); however, since I asked for help and you were nice enough try, the least I can do is post my rough work for you and others to see. I'm pretty sure I got it right this time; if not, someone, let me know.
:smile:
  • Handwritten working on lined paper: a subtraction of two permutation terms equals 236, marked with an X and a question 'So is correct?', then a rewritten version of the same subtraction equals 196, with 106 written beside it, and a handwritten explanation below.
  • Handwritten working on lined paper: crossed-out attempts at counting permutations with like objects, ending with the total 106, then two approaches listed: add permissible permutations, or subtract duplicates from all possible permutations.
