PH dependence of reduction of oxygen
In summary: Actually the opposite is true. Actually the opposite is true. The activity of the proton is higher in basic solution than in acidic solution.
Qube
Why is this true?
Why is it that the reduction of oxygen is more favored in acidic solution rather than in basic solution?
Acids are proton donors.
Does this have anything to do with the fact that the reduction of oxygen is in part a protonation reaction? In other words, what I'm seeing is simply that protonation is more favored in acidic media than in basic media?
Anyone
Exactly.
Another (but equivalent) explanation will take Nernst equation into account. Just like kinetics depends on the concentration of species, potential is a function of concentrations as well.
Likes 1 person
Borek said:
Exactly.
Sweet. Regarding the Nernst equation and how it predicts potential to decrease with increases in pH:
Is the protonation of oxygen dependent on kinetic or thermodynamic factors? I'm guessing thermodynamic factors because in more basic medium, the thermodynamic potential for protonation decreases - i.e. the species in basic media are weaker acids than hydronium ion. In strongly basic solution the most viable acid is water, and that's not a particularly strong acid.
Could kinetic factors also play a role?
Nernst equation is about thermodynamic - it assumes equilibrium situation and fast reaction (which is more or less equivalent of doing the measurements with infinitely low current). When the reaction is slow observed potentials will vary from those predicted by the Nernst equation. That's where overpotentials come in - we have to increase the potential to speed up the reaction. That's why you will observe chlorine evolving from the solution of chlorides, even if potentials suggest oxygen should evolve first - oxygen is just pretty lazy and never reacts fast on electrodes :wink:
Cool. So why does the potential decrease relative to the standard hydrogen electrode as the pH goes up for the oxidation of hydrogen protons? I'm guessing that it's easier taking hydrogen from hydronium ion in acidic solution than it is taking hydrogen from water in basic solution, since hydronium ion is less stable than water?
They are not "easier to remove" - there are just more of them, so if anything, they are "easily available".
Why not just take protons from water then? There are 50 plus moles of water even in most acidic solutions ... Excluding things like 18 M sulfuric acid.
There is a difference between proton in a water molecule and proton in hydronium cation. The latter is much easier to remove.
Note that because of water autodissociation hydronium is always present in the solution, just its concentration changes.
Why much easier? Isn't it the same HO bond?
No, its not the same. Besides, in the case of water you get an anion and a cation (so they attract) in the case of hydronium you get a cation and a neutral water molecule (so the attraction is between a charge and a dipole, and is orders of magnitude weaker).
Gotcha. Does this have to do with the Ka values of hydronium ion and water?
All these things are related in some way.
So if I'm understanding you correctly the reduction of H+ in water solution to hydrogen gas is dependent on the availability of protons. It is easier to take a positive charge from a positively charged molecule rather than a positive charge from a neutral molecule, so the reduction of H+ in acidic solution is easier than the reduction of H+ in neutral solution, in which the main source of H+ will be water. And this is closely related to Ka values because Ka is a measure of the tendency of an acid to lose a proton to a base in water solution.
Yes.
Borek said:
Yes.
Isn't the activity of the proton higher in acidic solution than in basic solution?
1. How does pH affect the reduction of oxygen?
The pH of a solution can significantly impact the reduction of oxygen. At lower pH levels (acidity), the rate of oxygen reduction increases, while at higher pH levels (alkalinity), the rate decreases. This is because the concentration of hydrogen ions (H+) in the solution affects the activity of enzymes involved in the reduction process.
2. What is the optimal pH for the reduction of oxygen?
The optimal pH for the reduction of oxygen depends on the specific enzyme and reaction involved. Generally, most enzymes involved in oxygen reduction have an optimal pH range of 6-8, which is close to neutral. This is because the enzymes function best at this pH range, allowing for efficient reduction of oxygen.
3. How does the pH dependence of oxygen reduction relate to biological systems?
In biological systems, enzymes involved in oxygen reduction are typically found in specific organelles or compartments that maintain a specific pH. For example, the mitochondria, where cellular respiration occurs, maintains a pH of around 7.4, which is optimal for the enzymes involved in oxygen reduction. Any changes in pH can affect the efficiency of oxygen reduction and ultimately impact cellular function.
4. Can extreme pH levels affect the reduction of oxygen?
Extreme pH levels, either very acidic or very alkaline, can significantly impact the reduction of oxygen. At extremely low or high pH levels, the enzymes involved in oxygen reduction can become denatured, meaning they lose their shape and function. This can lead to a decrease in the rate of oxygen reduction and potentially disrupt biological processes.
5. How can the pH dependence of oxygen reduction be measured?
The pH dependence of oxygen reduction can be measured using various techniques, such as pH meters or colorimetric assays. These methods allow for the precise measurement of pH and can be used to determine the optimal pH for oxygen reduction. Additionally, changes in pH over time can also be monitored to assess the stability and efficiency of the reduction process.
  • Biology and Chemistry Homework Help
