PH of concentrated and dilute acids
  • Thread starter Thread starter Betadine
    Acids Ph
The discussion revolves around the relationship between the pH of concentrated and dilute acids, particularly focusing on the behavior of hydrogen ions in solutions of varying concentrations. Participants explore the implications of concentration on pH measurements and the complexities that arise in high ionic strength solutions.
  • Homework-related
  • One participant states that pH is a measure of hydrogen ion concentration and questions why dilute acids can have lower pH values than concentrated acids.
  • Another participant asks for examples and suggests that the behavior of activity coefficients in high ionic strength solutions may be relevant to the discussion.
  • A participant expresses confusion about the pH of dilute hydrochloric acid being 1.0 and wonders if concentrated hydrochloric acid could have a pH lower than 1.0, indicating uncertainty about the relationship between concentration and pH.
  • It is noted that concentrated hydrochloric acid can have a pH that is negative, and that the assumptions behind pH calculations become complicated in very concentrated solutions due to ion interactions.
  • A participant highlights that pure sulfuric acid, while logically expected to be highly acidic, presents a paradox as it contains no water, raising questions about the definition of pH in the absence of a solvent.
Participants express uncertainty and confusion regarding the relationship between the concentration of acids and their pH values. Multiple competing views remain about how pH should be interpreted in concentrated solutions, and the discussion does not reach a consensus.
Participants acknowledge limitations in their understanding, particularly regarding the assumptions made in pH calculations and the role of water in determining pH values in concentrated solutions.
Betadine
I understand that pH is a measure of the concentration of hydrogen ions in a solution.
A more concentrated acid would have more hydrogen ions in a given volume of solution? Wouldn't that mean that it should have a much lower pH?
Why then do we have the pH of dilute acids being lower?
Can you give examples? It is possible you refer to the way activity coefficients behave in high ionic strength solutions, but I would prefer to know what we are talking about before going into details.
Thank you for the reply, Borek :smile:
I am not too sure actually.
My thoughts are based on the pH of dilute hydrochloric acid. It's 1.0, which is very low.
Could it be that the pH of concentrated hydrochloric acid is lower than 1.0?
In other words, maybe for a particular named acid, its concentrated version will always have a lower pH than its dilute solution? Sorry, I am confused and just jumping to conclusions. Hehe.
Yes, it can even get negative.
In very concentrated solutions things get complicated. Our methods of pH calculation (and to some effect measurement) assume ions don't interact too strongly as they are separated by copious amounts of water. When there is not enough water molecules, these assumptions no longer work, and rather unexpected things start to happen.
pH is a measurement of H+ activity in water solution. Think about pure sulfuric acid - simple logic tells us it should be highly acidic. Well, if it is pure, there is no water at all! What water solution, when there is no water?
