Physical Interpretation of a Vector Quantity
The discussion revolves around proving the relationship between the time derivative of the dot product of acceleration and the cross product of velocity and position vectors. The physical significance of this vector quantity is explored, indicating that the cross product creates a normal vector to the plane formed by velocity and position, while the dot product measures the projection of acceleration onto this normal. A zero dot product suggests that acceleration is orthogonal to the normal vector, indicating it lies within the plane formed by velocity and position. Conversely, a non-zero value indicates a component of acceleration both in the plane and along the normal, leading to a spiraling motion away from the plane. The conversation also addresses clarification of notation and potential confusion regarding vector definitions.
Bashyboy
If \mathbf{r}, \mathbf{v},\mathbf{a} denote the position, velocity, and acceleration of a particle, prove that
\frac{d}{dt} [\mathbf{a} \cdot (\mathbf{v} \times \mathbf{r})] = \dot{ \mathbf{a}} \cdot (\mathbf{v} \times \mathbf{r})
I have already proven the result, but am now wondering the what the physical significance of this vector quantity is. I believe I have some idea:
The vectors \mathbf{v} and \mathbf{r} create their own two dimensional subspace (a plane) in \mathbb{R}^3, with \mathbf{v} \times \mathbf{r} being normal to this plane. The dot product of this with the acceleration vector \mathbf{a} gives the projection of the acceleration vector onto the normal vector, it is a measure of how parallel they are. If the dot product is zero, then this implies \mathbf{a} is orthogonal to the vector \mathbf{v} \times \mathbf{r}, and that it lies in the plane \mathbf{v} and \mathbf{r} create. If it is not zero, then the this implies that the acceleration vector has a component lying in the plane, and a component parallel to the normal of the plane. This causes the particle to spiral away from the plane.
Does this seem correct?
Can you define your notation better?
The question says ##\mathbf{a}## denotes the position. In your solution you say it is the acceleration vector.
What do ##\mathbf{b}## and ##\mathbf{c}## have to do with the question?
And what are ##\mathbf{v}## and ##\mathbf{r}##?
:confused::confused::confused:
Whoops, I am terribly sorry. I just edited my original post.
