What are the rational solutions to the square root of four?
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Physical
The discussion revolves around the distinction between physical and unphysical states in the context of general relativity (GR) and quantum field theory (QFT). Participants explore the philosophical implications of this distinction, its dependence on experimental verification, and the nature of mathematical entities in relation to physical reality.
  • Philosophical exploration, Technical explanation, Conceptual clarification, Debate/contested
  • Some participants propose that a physical state must be verifiable through experiments, while an unphysical state lacks this capability.
  • Others argue that the designation of a state as unphysical is often a matter of convenience, depending on the context and boundary conditions of the system being studied.
  • A participant mentions that what is considered unphysical may change over time as scientific understanding evolves, excluding logical contradictions.
  • There are discussions about "ghost states" in quantum gauge-field theories, with some participants questioning why these states are deemed unphysical and whether they can exist in reality.
  • One participant elaborates on the role of Faddeev-Popov ghosts in QFT, explaining their necessity in canceling contributions from unphysical components of gauge fields.
  • Another participant briefly mentions the mathematical solutions to the square root of four, indicating a preference for rational solutions over imaginary ones.
Participants express a range of views on the nature of physical versus unphysical states, with no consensus reached on the definitions or implications of these terms. The discussion remains unresolved regarding the criteria that classify states as physical or unphysical.
Some claims depend on specific definitions and contexts within GR and QFT, and there are unresolved questions about the implications of ghost states and their role in physical theories.
I was and am reading quite a lot of books on GR and QFT and there's the distinction between a physical state and an unphysical state.
What is the difference?
What makes a state physical?
I know this is a bit philosophical .
Doesn't this distinction change with time and experiments?
I think this will fall into the Potter Stewart "I know it when I see it" definition.
As an example, I might solve for the electric field from a configuration of charges and have two solutions - one that gets small when I am far from the ensemble of charges and one that gets larger the farther away I get. I would dismiss the second solution as unphysical.
Can you tell us more about which books you're reading and the context in which they're making this distinction?
When I think of a state it implies the existence of a system. That is, a system is in some particular state. If the state is physical then there are experiments that can be performed, at least in principle, to verify the state. On the other hand if there is no experiment that can be performed, even in principle, to verify the state of a system then the state is not physical.
I think the designation as unphysical is merely one of convenience, and not, in a narrow sense, at all worrisome. Subsystems (this contrivance or that field) are written down without initially worrying about interactions with all the myriad other degrees of freedom. To solve a real world system boundaries in time and space must be specified. It turns out that some subset of boundary conditions are never encountered for the subsystem and these are simply declared inutile. There is no particular reason to expect otherwise.
Specifically, now I am reading on and off the book Perutrbative QCD by Muller.
Oldie but Goldie.
Just to expand on an already excellent answer, the solution which gets larger with increased distance is physical, it's just not the physics you were looking for. The solution which increases with distance describes sources residing at infinity. One needs both the field equations and the correct boundary conditions to describe a given physical problem.
It seems to me that what is unphysical may someday in the future turn to be physical, of course not including logical contradictions, which are discarded anyway.
There are many examples of unphysical or immaterial entities. Mathematics is an immaterial entity. So are the laws of logic. While certain types of thought cause the brain to “fire” differently on a scan, no neurologist on the planet can tell you what you are thinking - they must ask you for that information leading many to conclude that the soul is immaterial. Likewise, many religions teach that “God” is immaterial. You’re right that this question touches both physics and philosophy - nothing wrong with that.
I don't know what your book means by "unphysical states". If it's in the context of quantum gauge-field theories, it may refer to various "ghost states", i.e., contributions from unphysical components of the gauge fields which have to be canceled by the either unphysical Faddeev Popov ghosts.
Why those are unphysical? do we argue that such ghosts cannot exist in reality? why not?
The ghosts have been introduced in the formalism of calculating proper vertex functions to cancel the contribution from unphysical pieces of the gauge fields.
Take, as the most simple example, QED, i.e., the (un-Higgsed) U(1) gauge theory describing a Dirac field ("electrons and positrons") interacting through a minimally coupled U(1) gauge field ("photons"). First you start with four gauge fields.
The physical meaning is in the asymptotic free states, and as you well know, what's described with them are free photons being composed in terms of momentum-helicity single-photon Fock states. Of these only the 2 helicity states are physical, i.e., two field degrees of freedom are unphysical already in the sense of asymptic free states.
Now when calculating higher-order corrections (loops in Feynman diagrams) you formally sum also over the unphysical states, and this is on the first glance fatal, because it means you sum over states which have a negative norm, and the so calculated naive S-matrix wouldn't be unitary and also the microcausality condition may does not hold.
The path-integral formalism then shows that the correct way is to integrate over one physical field configuration only once and not over the infinitely many possibilities describe one and the same state expressed in different "gauges". So you choose a gauge-fixing condition and make sure by an appropriate functional ##\delta## distribution that you only pick out the one gauge configuration subject to this constraint. However, this is not so easily implemented in terms of a perturbative treatment, and that's why you use the trick to integrate over the gauge group and then expressing the arising functional determinant in the pertinent path-integral measure in terms of also unphysical Faddeev Popov ghost fields (which are formally scalar fields but implemented in the path integral as Grassmann fields, because the corresponding functional Jacobi determinant is in the numerator rather than the denominator), and these exactly cancel the contributions from the unphysical states of the gauge field.
In QED the Faddeev-Popov ghosts in the usual linear gauges are non-interacting and thus can be omitted, but that's not so for the non-Abelian case.
For details, see my QFT notes:
https://itp.uni-frankfurt.de/~hees/publ/lect.pdf
The square root of four has two rational solutions. We usually pick 2 instead of 2i.
## (2i)^2=-4## and not ##4##!
You meant ##\pm 2##.
14K
