Physics highest point reached by skateboarder
  • Thread starter Thread starter triplel777
    Physics Point
9 replies · 4K views
triplel777
A skateboarder shoots off a ramp with a velocity of 6.5 m/s, directed at an angle of 55° above the horizontal. The end of the ramp is 1.5 m above the ground. Let the x-axis be parallel to the ground, the +y direction be vertically upward, and take as the origin the point on the ground directly below the top of the ramp.
(a) How high above the ground is the highest point that the skateboarder reaches?
(b) When the skateboarder reaches the highest point, how far is this point horizontally from the end of the ramp?
(a) i figured i need y+1.5 for my answer so i need to find y.
so sin55= y/6.5
y= 5.32
y+1.5 = 6.82 but its wrong
(b) i thought it was as easy as using the phythagoram therom and said a^2 + 5.32^2 = 6.5^2
a= 3.73 but that's wrong
i inserted the pictures i drew for each part.
First write down the kinematics equations for two-dimensional projectile motion. If you are not sure what to do with them, we will help along, but we need something to point to.
triplel777 said:
ok y=y_0 + v_0*t-g/2*t^2
now what do i do?
That's not the kinematics equation that we want/require, since it involves time, which does not feature in part(a) of the question.
For part (a), what is the final velocity (y-component) of the skateboarder at the highest point?
For part (b), what is the time taken for the skateboarder to reach this highest point? What is his velocity in the x-direction throughout the trajectory?
ok the only one that doesn't involve time is y-y_0=V_0y/V_0x * (X-X_0) - g(x-X_0)^2/ 2*V^2_0
There is another one that does not involve time and has no "x" subscripts.
ok well I am looking at my formula sheet given to me by the instructor and the only other formula on there that does not have t or an x subscript is V^2- V_0^2 = 2a *(x-x_0)
and that formula is not even on the chapter we are in.
Use this for the motion in the y-direction, but first you need to figure out what to put in for these quantities - which ones you know and which one you are looking for. Any ideas?
ok well the initial velocity would be 0. v= 6.5, X=1.5 so we don't know a or X_0
You know a - don't forget that once he gets airborne he is in free fall. You may not know x_0, but you don't care what it is. You are looking for his vertical displacement which is x - x_0. So ...
