Plane through P(9,2,-5) with normal vector n=(3,-4,6)
8 replies · 3K views · last reply
Specter
Find the scalar, vector, and parametric equations of a plane that has a normal vector n=(3,-4,6) and passes through point P(9,2,-5)
Finding the scalar equation:
Ax+By+Cz+D=0
3x-4y+6z+D=0
3(9)-4(2)+6(-5)+D=0
-11+D=0
D=11
3x-4y+6z+11=0 is the scalar equation.
To find the vector equation I need a point and two direction vectors.
3x-4y+6z+11=0
6z=-3x+4y-11
z=-3/6 x + 4/6 y -11/6
z=-1/2 x +4/6 y - 11/6
Let x=0 and y=0
z=-11/6
One point is Q(0,0,-11/6)
Let x=0 and z=1
3(0)-4y+6(1)+11=0
-4y+6+11=0
-4y+17=0
y=17/4
Another point is R(0, 17/4, 1)
Now I have 3 points, I need 2 direction vectors.
PQ=Q-P=(0,0,-11/6)-(9,2,-5)
=(-9,-2,19/6)
PR=R-P=(0,17/4,0)-(9,2,-5)
=(-9,9/4,5)
The vector equation should be (x,y,z)=(9,2,-5)+t(-9,-2,19/6)+s(-9,9/4,5), where s and t are any real numbers.
Parametric equations are
x=9-9t-9s
y=2-2t+9/4 s
z=-5+19/6 t + 5s
I think I did this correctly but I'm not sure how I can check to see if my answer is correct. If anyone could look this over and let me know how I could check it myself would be great. Thank you.
Ax+By+Cz+D=0
3x-4y+6z+D=0
3(9)-4(2)+6(-5)+D=0
-11+D=0
D=11
I get this as well.
3x-4y+6z+11=0
6z=-3x+4y-11
Let x=0 and y=0
z=-11/6
Let x=0 and z=1
3(0)-4y+6(1)+11=0
-4y+6+11=0
-4y+17=0
y=17/4
=(-9,-2,19/6)
=(-9,9/4,5)
You have a mistake here.
x=9-9t-9s
y=2-2t+9/4 s
z=-5+19/6 t + 5s
You can use your scalar equation to find a couple more points (which you did).
Verify that the two direction vectors you found are actually perpendicular to the given normal vector. Note that one of them doesn't work.
You can also check your parametric equations by verifying that there are specific values of t and s that generate the points you already know.
Mark44 said:
I get this as well.
How can I verify that the direction vectors are perpendicular to the normal vector? I don't really know what I'm doing. I am not sure where the mistake is either.
Thank you for the reply :)
Two vectors are perpendicular if their dot product is 0.
Alright, so the dot product of the two direction vectors PQ and PR is not 0, meaning they are not perpendicular to the normal vector. How can I find out which direction vector is the vector causing the problems?
I think you misunderstood what I said. Find the dot product of each direction vector with the normal, not with each other. The two direction vectors don't have to be perpendicular, but each has to be perpendicular to the normal.
Yeah I did misunderstand.
PQ⋅n=0
PR⋅n=-6
So this tells me that PR does not work. Now what can I do to fix this?
Thanks!
Check your work on getting PR. You have a mistake. Your point R is fine, but you made an error in calculating the vector PR.
I checked my work for ##\vec PR## and got ##(-9,- \frac {19} 4, 5)##
Meaning that the vector equation would be ##(x,y,z)=(9,2,-5)+t(-9,-2,\frac {19} 6)+s(-9,-\frac {19} 4,5)## where s and t are any real numbers.
The parametric equations would be
##x=9-9t-9s
\\y=2-2t-\frac {19} 4s
\\ z=-5+\frac {19} 6t+5s##
