- 18
Why don't you stop lying, none of you're posts said "let's switch the context". Instead you repeatedly made nasty accusations that I was making "mistakes" and "errors" when I just took you at your word, and then you pretended like you hadn't said what you had in fact said. Read again:chinglu1998 said:We are doing a 2nd calculation.Is this an intellectual challenge?
We are doing a new problem.
This is not reasonable to try to trap me in like this when I clearly said let's switch the context.
chinglu1998 said:Geez, please take the clock as the stationary frame wrt to the observer.
JesseM said:In that case there is only one frame to consider, the frame where both the clock and observer are at rest
Then in the only post of yours that used the word "context", you said that the context was still about "the clock at rest wrt to the observer":chinglu1998 said:Where in the WIKI article is the clock at rest with the observer? You make many mistakes.
chinglu1998 said:I have the context.
I want to see your calculation with the clock at rest wrt to the observer. See i even followed your rules, as if that was the issue.
JesseM said:Then it's simple, in the observer's frame the light source is at rest so there is no aberration, therefore the light just travels on a vertical path of length L from the bottom to the top, so the time is [tex]\Delta t = \frac{L}{c}[/tex] to go from bottom to top.
So in both cases, you said the observer was at rest relative to the clock, I responded to that, and then you accused me of a mistake/error. There was nothing like "oh sorry, I know I said the observer was at rest relative to the clock but now I want to change the context and talk about an observer moving relative to the clock" (when I pointed out you had changed your story, your response in post #248 was "whatever"). So you are either confused or trolling, I'm thinking the latter looks pretty likely now. If you want to show you're not a troll you can acknowledge that you were incorrect to accuse me of mistakes in the two posts above, if you don't do that I will be pretty confident that you are trolling and will no longer respond to your posts (and will probably also report this thread to the mods in hopes they will lock it so others aren't fooled into wasting time responding as if your questions were asked in earnest).chinglu1998 said:What?
The observer's frame does not have the light source, the clock does. This is an error.
To calculate the "time intervals between the frames", one of the time intervals we must calculate is the time in the observer's frame. What the hell does it mean to calculate the time in the observer's frame "in the view of the clock frame"? Are you asking to apply the LT to the times in the clock frame? Are you asking to figure out the clock frame's view of the two clocks the observer uses to locally measure the time-coordinates of the light leaving the bottom mirror and the light hitting the top one? If the question is serious and not a trollish provocation, you need to explain precisely what it is you want calculated here.chinglu1998 said:We are trying to calculate the clock at rest and the observer is moving and calculate the time intervals between the frames in the view of the clock frame. Can you do this?
