Possible error in Wikipedia's time dilation article
312 replies · 40K views
chinglu1998 said:
Oh, no I do not agree with absolute positions. I know the conventions. I just know every scrap of evidence on the WIKI problem proves the unprimed is the stationary frame.
Yes, of course the wiki labels unprimed as the stationary frame, because they are defining "stationary" vs. "moving" relative to the clock and the clock is at rest in the stationary frame. And as I said:
On the other hand, if you make the equally arbitrary choice to label the clock's frame as "stationary" and the observer's frame as "moving", then it can be interpreted in this way:
(time between two readings on the clock as measured in moving frame) = (time between two readings on the clock as measured in stationary frame)*gamma
Do you agree that this equation is correct or do you think it's wrong? If you agree it's correct, you can see that with t' as time in moving frame and t as time in stationary frame, this is exactly the same as the wiki's t' = t*gamma
I agree with Jesse and others that it is best to avoid the concept of the velocity of a reference frame. It is better to think in terms of the velocity of a clock relative to a given reference frame without any care for the velocity of the reference frame itself. When people say "in the rest frame" it is really shorthand for "the reference frame in which in the clock (or particle) is at rest". As Dalespam said, it probably best to use the Lorentz transformation:
[tex]t' = \frac{ t - v x/c^2}{\sqrt{1-v^2/c^2}} = ( t - v x/c^2) \gamma[/tex]
where t' is the time interval measured by clocks at rest in S' and t is the time interval measured by clocks at rest in the unprimed S frame. v is the velocity of S and S' relative to each other. Note that there is no implication of whether S' or S is at rest.
Now if [itex]x = 0[/itex] in the transformation then the time interval measured in the unprimed frame is the time measured by a single clock that is at rest in the unprimed frame which is the proper time denoted by [itex]t_0[/itex] and the time dilation equation can be written as:
[tex]t' = t_0 \gamma[/tex]
where it is understood that [itex]t_0[/itex] is the proper time measured by a single clock. The prime symbol no longer has any significance in this formulation. Using the primed notation can cause confusion, because there is no universal convention for which frame is primed and the context of the equation has to be carefully examined.
JesseM said:
There is no coordinate system where all the dynamical predictions of Newtonian mechanics hold good (for example, Newtonian dynamics would predict that a clock ticks at the same rate regardless of its velocity). But if you pick some specific features of Newtonian mechanics which still hold in relativity, like the fact that an object moving at constant velocity remains at that velocity unless acted on by a force, then these features hold in all inertial frames in relativity, not just one. If you disagree, please name a specific Newtonian law which you think holds in one inertial frame (the 'stationary' one) but not others.
I am going to quote Einstein again. You are refuting Einstein?
Let us take a system of co-ordinates in which the equations of Newtonian mechanics hold good.2 In order to render our presentation more precise and to distinguish this system of co-ordinates verbally from others which will be introduced hereafter, we call it the ``stationary system.''
http://www.fourmilab.ch/etexts/einstein/specrel/www/
Uh, I think you are forgetting about the relativity of simultaneity. A "light sphere" is just the set of points in spacetime that light from a flash has reached at a single moment in time in one frame, but if you map this set of points to a different frame, then in that frame they will consist of events at different times. If instead you consider the light cone as is normally done in relativity, then if you look at the subset of events on that cone which all occur at some time T in the unprimed frame, their positions in the unprimed frame will form a sphere satisfying x2 + y2 + z2 = c2 T2, and likewise if you look at a different subset of events on that cone which all occur at some time T' in the primed frame, their positions in the primed frame will form a sphere satisfying x'2 + y'2 + z'2 = c2 T'2. You really are very confused if you think that light expands spherically in one inertial frame but elliptically in a different inertial frame--that would violate both the first and second postulates of special relativity! This issue of light spheres vs. light cones and why each frame sees the light as a sphere at any single instant was discussed extensively on this thread, if you're interested.
I wrote the Minkowsky interpretation of the Euclidian light sphere mapped from the stationary system of coordinates did not have an equal radius in all directions.
That implies the relativity of simultaneity. Seemed obvious to me.
I also know you will type thousands of pages rather than simply admitting you are wrong.
The problem is you keep on getting caught up on the name of the frames. Let's say I have two frame the stationary frame and the moving frame. The moving frame is moving at .6c compared to stationary frame. Now from the moving frame of reference how much fast is the stationary frames clock moving?
chinglu1998 said:
Then is it possible you compare the equations?
WIKI says t' = t γ
The others say t' = t / γ.
Can you see the difference?
I agree the Wiki article is a little confusing when one is used to seeing t' = t / y. I tried to edit it to clarify a while back with the moving mirrors part, but my clarification ended up adding another mirror that didn't exist within the diagrams and probably complicated it more in the long run, so it was dropped. I might try again some other way at some point.
Anyway, the time dilation formula can be taken either way, only depending upon which frame we consider at rest, or which is our frame of reference. Usually we take the unprimed frame to be our frame of reference which is at rest while the unprimed frame is moving, but in the Wiki article, it is the other way around. It is still correct either way, however, since the primed frame is time dilating in the same way from the perspective of the unprimed as the unprimed frame is from the perspective of the primed frame.
In other words, there is no absolute "one frame is time dilating to the other", where either t = t' / y or t' = t / y, but each time dilates relative to the other in the same way, depending upon which frame's perspective we are taking. To see this, as mentioned before in another thread, we should really use four variables, say tAA, tAB, tBA, and tBB, not just the two t and t', since the dual purpose of the same two variables becomes unclear. With the four variables, tAA will be the time that frame A observes of frame A's own clock, tAB will be the time that frame A observes of frame B's clock, and so forth. Using these, we can now see that we actually have two sets of equations, depending upon which frame is doing the observing. For frame A, it is tAB = tAA / y. For frame B, it becomes tBA = tBB / y.
Can you show me numbers?
I expect to see the t' less than t because of time dilation. I can post Einstein'ss equation again also that verifies this.
I'm not "refuting" him, I'm just saying you have to understand he was writing for an audience of physicists who would not jump to the conclusion that "equations of Newtonian mechanics hold good" was meant to imply that every possible dynamical equation in Newtonian mechanics holds--for example, the instantaneous action-at-a-distance of Newtonian gravity obviously doesn't hold in relativity, nor do rigid body equations which assume that a force applied to the back end of an object will instantaneously accelerate the front end. Do you disagree, and think he was talking about every conceivable Newtonian equation?
So you agree that in every inertial frame, if we look at the position of the light at a single simultaneous instant in that frame, the position of the light at that instant forms a sphere in that frame satisfying an equation like x2 + y2 + z2 = c2 T2 in the coordinates of that frame? If you do agree, I don't see why you use this example to try to prove that there is only one frame where "Euclidean geometry" holds while in the other ones Minkowski geometry (not 'Minkowsky') holds.
where it is understood that [itex]t_0[/itex] is the proper time measured by a single clock. The above equation can also be written as:
[tex]t = t_0 \gamma[/tex]
because proper time has an unambiguous definition, the prime symbol no longer has any significance in this formulation. The time interval [itex]t[/itex] is the time interval measured by multiple clocks at rest in a reference frame moving with velocity v relative to the rest reference frame of the single clock that measures the proper time [itex]t_o[/itex] between two events. Using the primed notation can cause confusion, because there is no universal convention for which frame is primed and the context of the equation has to be carefully examined.
Sure I know how to follow this convention.
Anyway, this OP is about whether WIKI has made an error on said link. What do you say?
This is about the OP and I am not making any claims one way or the other about rest or moving.
I simple reads articles and see what we have.
Are you claiming the WIKI article has the primed frame as stationary?
Yes, no one said any absolutes.
The WIKI article said the unprimed frame is the rest frame.
Light abberation says the unprimed frame is the rest frame.
But, it has the primed frame beating faster. This is an error.
Sure. Suppose the relative velocity between the primed frame and the unprimed frame is 0.6c (so gamma=1.25), and we have a clock at rest in the unprimed frame at position x=0. Then if the event of the clock reading a time of 0 happens at t=0, the event of the clock reading a time of 20 happens at t=20. So, the time between these events in the unprimed frame, [tex]\Delta t[/tex], equals 20. According to the Lorentz transformation, the times of these events in the primed frame will be given by t' = 1.25*(t - 0.6x/c). So since the event of the clock reading 0 happened at x=0, t=0 in the unprimed frame, in the primed frame it happens at time t'=1.25*(0 - 0)=0; and since the event of the clock reading 20 happens at x=0, t=20 in the unprimed frame, in the primed frame it happens at time t'=1.25*(20 - 0)=25. So the time between these events in the primed frame, [tex]\Delta t'[/tex], equals 25. Therefore just as the wiki says, the time dilation equation relating the time in each frame between two events on the worldline of a clock at rest in the unprimed frame would be:
[tex]\Delta t' = \Delta t * 1.25[/tex]
Let us not bring in gravity and acceleration. We are talking SR.
I did not say there was only one frame where the Euclidean geometry holds true for the light sphere. I said in the context of the stationary system, that holds true.
You can take any frame as stationary and the light postulate holds true, ie x2 + y2 + z2 = c2 t2
What?
The stationary clock elapses 20s and the moving clock elapses 25s?
So under your new theory, moving clocks elapse more time than stationary clocks? How is that time dilation?
Why not simply admit you were wrong about the WIKI article? It would save you lots of additional errors.
chinglu1998, the wiki article is correct, but thanks for providing a wonderful example of why the time dilation formula should always be avoided.
Why?
That is exactly what I am saying.
from the wiki article
From the frame of reference of a moving observer traveling at the speed v (diagram at lower right), the light pulse traces out a longer, angled path. The second postulate of special relativity states that the speed of light is constant in all frames, which implies a lengthening of the period of this clock from the moving observer's perspective. That is to say, in a frame moving relative to the clock, the clock appears to be running more slowly.
They are using the frame of reference of the moving observer for the t'. So yes the primed frame is "stationary" in it's own frame of reference.
DaleSpam said:
Because you have gone on for three pages in confusion about a formula when you could have avoided the confusion entirely simply by not using the formula .
Dale, I know how to do it either way.
But, since I am confused and the article said the unprimed frame is stationary and I provided 6 links that reversed the WIKI article, can you explain your position?
chinglu1998 said:
Why?
The wiki article is correct because it has the right formula given the convention used and clearly identified in the article. There is no right or wrong about if the primed frame is stationary or moving, it is only a convention and having identified the convention they provide the correct formula. Your 6 links are simply not relevant, except perhaps to show that other authors choose a different convention.
That's fine.
So I must always assume when an article says the unprimed frame is at rest, it is not actually at rest, the other frame is. And, when the article says the primed frame is moving, it is actually not moving but at rest. Do I understand you correctly?
The wikipedia article says that the unprimed frame is the rest frame of the light clock, this implies that no aberration will be observed in the unprimed frame (as is indicated in the upper picture accompanying the section in question).
[tex]$\Delta{}t'$[/tex] is the period of one cycle of the clock in the frame in which the clock is in motion (the one corresponding to the lower picture with aberration). The equation in question relates the period of the clock in the frame in which it is observed to move with its period in the clock's rest frame. Since frequency is inversely proportional to period, the same equation implies that [tex]\Delta{}n=\frac{\Delta{}n'}{\gamma}[/tex] where n denotes the number of cycles/ticks of the clock in the appropriate frame (following the convention of the wikipedia article). Thus, the equation says that a moving clock will be observed to tick less frequently in a frame in which it moves (i.e., all else being equal, moving clocks are observed to "run slow" compared to ones at rest, as expected).
chinglu1998 said:
That's fine.
You don't assume anything you read it to see what it's actually saying. There are two frames of reference it doesn't matter they they are called. But when you look at them in there own frame of reference and aren't accelerating they are at rest in there own frame of reference.
So if I say I have two frames a moving and a stationary frame. Then say from the frame of reference of the moving frame, that frame isn't actually moving in it's own frame.
chinglu1998 said:
What?
There is no single "moving clock". 25s is the time measured in the primed ('moving') frame between two events on the worldline of the clock at rest in the unprimed ('stationary') frame. But these events occur at two different positions in the primed frame, so you'd need a pair of clocks at rest and synchronized in the primed frame to assign time-coordinates to both events in a local way, after which you could figure out their difference in time-coordinates. That's how position and time coordinates are supposed to be assigned in SR, using a lattice of rulers and clocks at rest relative to one another and synchronized using the Einstein synchronization convention, as illustrated here:
Einstein also discusses the idea that coordinate times and coordinate positions should be defined using local measurements on a set of rulers and synchronized clocks in sections 1 and 2 of the 1905 paper you linked to.
As always, "moving" and "stationary" are arbitrary labels. Changing the labels does not magically change any facts about the amount of coordinate time between two specific events in different frames. Instead of playing these silly word-games, why don't you go through my analysis using the Lorentz transformation and figure out specifically where you think I made an error? Do you disagree that if a clock is at rest at x=0 in the unprimed frame, then the coordinates of it showing a time of 0 would be x=0,t=0 while the coordinates of it showing a time of 20 would be x=0,t=20? Do you disagree that when we transform x=0,t=0 into the primed frame we get t'=0, and when we transform x=0,t=20 into the primed frame we get t'=25? Please address these quantitative specifics instead of retreating into vague word-games.
This is a meaningless pair of sentences. Every time you use the term "at rest" you must specify "at rest with respect to ___", and every time you use the word "moving" you must specify "moving with respect to ___".
Well it is hard to say because it appears someone is editing (and making a bit of a mess of - no "t" on the RHS of the equations) the first part of the article http://en.wikipedia.org/wiki/Time_d...nce_of_time_dilation_due_to_relative_velocity as we speak.
Further down http://en.wikipedia.org/wiki/Time_dilation#Time_dilation_due_to_relative_velocity the Wiki article states that:
[tex]\Delta t' = \gamma \Delta t[/tex]
where Δt is the time interval between two co-local events (i.e. happening at the same place) for an observer in some inertial frame (e.g. ticks on his clock) – this is known as the proper time..
which is in exact agreement with what I was saying. Do you agree that part is correct?
<EDIT> O.K. it appears the WIki article has been edited yet again back to its original form. It now states that:
[tex]\Delta t' = \frac{ \Delta t}{\sqrt{1-v^2/c^2}}[/tex]
and makes it absolutely clear from the definition [itex]\Delta t = 2L/c[/itex] and the accompanying diagrams that [itex]\Delta t[/itex] is the proper time measured in the rest frame of the light clock. This means the Wiki article is unambiguous and correct.
SR deals with acceleration--it can deal with the behavior of accelerated objects even if you only analyze them from the perspective of inertial frames, but in any case modern physicists would say that even if you use accelerated frames you're still in the domain of "SR" as long as there is no spacetime curvature.
Do you agree that Einstein's statement should not be interpreted to mean that all Newtonian laws "hold good", but only some of them like the law of inertia? Yes or no?
Even if you choose to label one frame as "stationary" and another as "moving", it is still true in the moving frame that the light postulate holds true in the coordinates of that frame (light has a coordinate velocity of c in all directions in the moving frame), and that in the coordinates of that frame the position of the light at any specific time T' satisfies x'2 + y'2 + z'2 = c2 T'2. So you still haven't given any non-confused explanation of what you meant in post #23 when you said "When you take a frame as stationary, you assume the Euclidian Geometry.
When you assume another frame is the moving frame, you apply the Minkowsky Geometry.
This is a vital distinction such that if the distinction is not clear, complete and total breakdown of SR occurs."
Agreed.
Agree with you conclusion about SR but not WIKI.
You have already agreed the article claims the clock at rest with the light source has no light abberation. Let's take that clock as stationary. That is legal right?
Now, the clock that sees the light abberation is moving compared to the unprimed frame clock. So let's agree WIKI is correct.
Let's say as everyone here is claiming that WIKI has this correct.
So, t' = tγ.
This means when the unprimed frame is at rest and observering the to clock, it is moving and beating faster than it rest clock.
To chinglu1998
Lets say there is a spaceship that's moving away from Earth at .6c.
From the ships frame of reference is the Earth's clock moving faster or slower than the one on the ship?
If you do the math on WIKI, you will find if you take the unprimed frame as rest with respect to the primed frame, then t' = t γ.
If you take the primed frame as rest with respect to the unprimed frame, then t' = t γ.
So either way, it is absolute that t' = t γ. Why is this? This light beam path for the primed frame is absolutly longer than that of the unprimed frame because of light abberation. This is not a relative issue.
darkhorror said:
To chinglu1998
Under SR, a moving clock is supposed to beat slower. What about the WIKI article?
So from my question which one is moving slower? the Earth or ship?
