Potential Divider: Understanding Its Purpose
2 replies · 4K views
Air
On reviewing the chapter on resistivity, I have come across a principle involving potential dividers. Can someone explain the purpose of this tool?
I think it is to vary the voltage so at one terminal the voltage is max and the other end it is zero.
According to my notes, you use a potential divider to produce a pd that you want but might not be able to get. (i.e. where the supply voltage is greater than what is actually needed by a load)
You can also use it to have a pd which follows temperature or Light intensity. Also, it can be modified to become a potentiometer.
Voltage dividers are typically used to output a specific voltage (whatever is needed in the circuit) that is somewhere between the supply voltage and close to zero.
CS
