Potential energy of a string question
The discussion revolves around calculating the change in elastic potential energy of a spring with a spring constant of 3200 N/m when its stretch or compression changes. The initial potential energy is given as 1.44 J, and the user correctly calculates the potential energy for a 2.0 cm stretch as 0.64 J. The confusion arises regarding how to determine the change in potential energy, with the user questioning whether to consider the initial and final states properly. Ultimately, it is clarified that the change in potential energy should be calculated as Uf - Ui, leading to a result of -0.80 J for the specified changes. The conversation highlights the common challenges in interpreting physics problems accurately.
genu
A spring with a spring constant of 3200 N/m is initially stretched until the elastic potential energy is 1.44J. (U=0 for no stretch) What is the change in the elastic potential energy if the initial stretch is changed to
a) a stretch of 2.0 cm,
b) a compression of 2.0 cm,
c) a compression of 4.0 cm?
U = 1/2kx^2
u=(3200N/m(0.002m)^2)/2
u=0.64
correct answer = -.80
Welcome to PF!
You calculated the potential energy when the spring is stretched to 2.00cm. The problem was to find the change of the potential energy, you got the correct answer for the stretch you just need to do a bit more with it to find the change of PE.
its a bit confusing, because it says "the elastic potential energy if the initial stretch is changed to..", so I assumed that they wanted the potential energy from 0 to the specified x...but I see now...
How do I know which way to substract though? is 1.44 considered Ui and x=2.0 cm considered Uf, and then it would be Uf - Ui = -0.80 J?
genu. you did that correctly and I think that true also that Uf-Ui is the answer
That's so true. Sometimes the biggest problem with physics questions is what the question means.
great..thx for the help
ya because problems always confuse and try to divert attention from actual meaning
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 22 ·
