Potential of parallel infinite charged wires
The discussion focuses on the potential generated by two infinitely long parallel wires with uniform charge densities of +λ and -λ. The potential at any point (x,y) is derived as V(x,y) = (λ/4πε₀)ln(((x+d)² + y²)/((x-d)² + y²)). The equipotential surfaces are shown to be circular cylinders, centered along the z-axis, with the equation x² + y² + d² - 2xd(k+1)/(k-1) = 0 defining circles in the x-y plane. The conclusion emphasizes that while the potential is independent of z, the infinite collection of circles forms a cylindrical surface.
  • Understanding of electric potential and charge distributions
  • Familiarity with logarithmic functions in physics
  • Knowledge of cylindrical coordinates and symmetry in electrostatics
  • Proficiency in algebraic manipulation and completing the square
  • Study the concept of electric potential from continuous charge distributions
  • Learn about the properties of equipotential surfaces in electrostatics
  • Explore the derivation and applications of Gauss's Law in cylindrical symmetry
  • Investigate the behavior of electric fields around charged wires and their implications
Students and professionals in physics, particularly those focusing on electromagnetism, electrical engineers, and anyone interested in understanding the behavior of electric fields and potentials in cylindrical geometries.
musemonkey
1. Two infinitely long wires running parallel to the x-axis carry uniform charge densities +\lambda and -\lambda. Find the potential at any point. Show that the equipotential surfaces are circular cylinders, and locate the axis and radius of the cylinder corresponding to a given potential V_0
2. Homework Equations .
Potential of one wire charge density \lambda I calculated to be :
V_a(b) = \frac{-\lambda}{2\pi\epsilon_0} \ln (b/a) where a,b are shortest distances to the wire, and distance a is the reference.
I let the wires be equidistant from the x-axis, denoting the distance d. I put the -\lambda wire at (-d,0) and the +\lambda at (d,0).
Setting the reference at the origin, the reference distance for both wires is a = d. Letting r_+, r_- be the distance from a point (x,y) to the positive and negative wires, respectively, the potential at (x,y) is then
V(x,y) = \frac{\lambda}{2\pi\epsilon_0}( -\ln(r_+/d) + ln(r_-/d) )
= \frac{\lambda}{2\pi\epsilon_0}\ln(\frac{r_-}{r_+}).
The distances are
r_+ = \sqrt{(x-d)^2 + y^2}
r_- = \sqrt{(x+d)^2 + y^2}.
So the potential can be written
V(x,y) = \frac{\lambda}{4\pi\epsilon_0}\ln(\frac{(x+d)^2 + y^2}{(x-d)^2 + y^2}).
If so, then the eqn. of a V_0 equipotential surface is
k = \frac{(x+d)^2 + y^2}{(x-d)^2 + y^2}) where k = \exp( \frac{4\pi\epsilon_0 V_0}{\lambda} ).
This simplifies to
x^2 + y^2 + d^2 - 2xd\frac{k+1}{k-1} = 0.
and I don't see how this eqn. could define a cylinder, and moreover, on intuitive grounds, I don't see how a cylinder could possibly be the geometry of the equipotential surfaces. By symmetry, an equipotential cylinder would have to be centered at the origin -- right? -- but that would means that the potential at (d + \varepsilon, 0 ) a bit to the right of the positive wire would be the same as the potential at (-d - \varepsilon, 0 ) a bit to the left of the negative wire!
Strictly speaking, x^2 + y^2 + d^2 - 2xd\frac{k+1}{k-1} = 0 defines a circle, not a cylinder. However, the potential is independent of z, so these circles are the same for a given V_0 all the way along the z-axis, and together this infinite collection of circles (of the same radius and center) define a cylindrical surface.
To see that your equation represents a circle, just "complete the square" in 'x', an you can rewrite your equation into the form (x-a)^2+y^2=R^2 which of course, represents a circle centered at (a,0) with radius R... What do you get for your a and R values?...Clearly, your cylinder is not centered at the origin, but rather runs parallel to the z-axis and is centered at (a,0).
Now that you mention it, that was the plain-as-day thing to do. Thanks!
