Azael
- 257
- 1
Find the potential outside a thin, circular disc with charge q.
Laplace's equation
DivgradU=0
Since the problem implies symmetry around phi its obvious the solution doesn't depend on phi.
I separate the differential equation into U=A(r)B(z)
Then its easy to find the solutions
B(z)=c(\lambda)e^{-\lambda z}
A(r)=J_0(\lambda r)
where J_0 is the 0'th bessel function.
So I have
U(r,z)=c(\lambda)e^{-\lambda z}J_0(\lambda r)
The general solution then becomes
\int_{-\infty}^{\infty}C(\lambda)e^{-\lambda z}J_0(\lambda r) d\lambda
The problem is that I don't have the slighest clue on how to find C. I know that far away from the disc the potential should tend toward the potential outside a point charge.
So if we work along the r plane and put z=0 we have the equation, when r is large
\int_{-\infty}^{\infty}C(\lambda)J_0(\lambda r) d\lambda= \frac{q}{4\pi\epsilon r}
If I instead work on the z axis I know that the potential is given by.
\int_{-\infty}^{\infty}C(\lambda)e^{-\lambda z} d\lambda= \frac{q}{2\pi\epsilon a^2}(\sqrt{z^2+a^2}-|z|)
How do I transform this to solve c?
Yoru right its a minus in the exp aswell. Edited my first post so its correct.
