Power dissipation in series resistors with 12V battery
5 replies · 3K views
sloan13
Basically, I need to know the power dissipation (W) for three resistors using aw 12V battery: 120, 80, and 50 ohms.
https://webwork2.uncc.edu/webwork2_files/tmp/Fall2014-Engr1201-Common/img/2ff2f0ce-cb10-3786-8109-c42346130316___1a2e5eeb-8657-3983-941f-b7d8a9123afa.gif
I think the formula for voltage drop is Voltage Drop = Resistance * Current, and I thought the formula for power dissipation was V^2/R.
It also asks for the current, which I think is 0.05A and voltage drop across all three resistors.
I think the answers for voltage drop are 6, 4, and 2.5 V, and the current was 0.05A.
I thought the power dissipation for the three resistors were 1.2, 1.8, and 2.9 W.
The website says I got "at least one wrong." Thanks, WeBWork.
I just got the power dissipation problems. All I need is the voltage drop. Apparently, V=IR doesn't apply here?
Adding your voltage drops gives 12.5V, which is more than your voltage source.
I also got a different current when I divided 12V/Rtotal. Can you show your work in those two steps?
12V/250(Rtotal) = 0.048A which I rounded to 0.05A.
Vdrop1 = 120 * .05 = 6
Vdrop2 = 80 * .05 = 4
Vdrop3 = 50* .05 = 2.5
Do you think I just rounded too early?
Yea, I reentered them without rounding, and they were correct. Thank you, berkeman.
Glad to help. Yeah, definitely don't round anything until the end. :smile:
