Can We Predict Damping Coefficient of a String Using Mathematical Simulation?
The discussion revolves around the feasibility of predicting the damping coefficient of a string through mathematical simulation. Participants explore various factors that may influence the damping coefficient, including physical properties of the string and environmental conditions. The conversation touches on theoretical considerations, practical applications, and experimental approaches.
  • Experimental/applied
  • One participant suggests that predicting the damping coefficient requires accounting for multiple variables such as string diameter, length, frequency, material density, elastic modulus, and atmospheric conditions.
  • Another participant argues against the possibility of accurate prediction due to the complexity and variability of the factors involved, suggesting that material property catalogs are often used for estimations.
  • A different viewpoint is presented, stating that the damping coefficient of an isolated string may not be useful, as real strings in instruments interact with their environment and components differently.
  • One participant proposes that air has a significant damping effect on strings, referencing an experiment to support this claim, while also acknowledging that their initial assumption may be partially incorrect.
  • Another participant emphasizes the importance of considering an ideal model of the string's environment, focusing on atmospheric conditions rather than the string's interaction with the instrument's body.
  • A later reply expresses hope that future equations for string behavior can incorporate the damping coefficient efficiently, likening it to a standardized component that can be easily integrated into broader models.
Participants express differing views on the predictability of the damping coefficient, with some asserting it is not feasible due to the complexity of variables, while others maintain that it can be approached through simulation with careful consideration of conditions. No consensus is reached on the utility of the damping coefficient in practical applications.
Participants highlight limitations related to the assumptions required for modeling, the dependence on specific definitions of damping, and the unresolved nature of how various factors interact in real-world scenarios.
Chrono G. Xay
Is it possible to predict the damping coefficient of a string using a mathematical simulation that included the string's diameter, length, frequency (and therefore tension), material density, and elastic modulus (if not also its Poisson's ratio) as opposed to simply looking at the amplitudes of each successive wave? I'm guessing that It would be even more accurate to factor in modes of vibration that are not just the fundamental, as well as how these modes are excited differently based upon where along the string's length it is initially deflected.
I would like to think that we can, but then again do I not also need the density of the atmosphere--assuming it's air, if not a vacuum--and the string's velocity (meaning I would probably need to know the distance of the string's initial transverse displacement, and therefore the restoring force of the deflected string?
I haven't been to find articles that I really understood and didn't just contain cursory knowledge:
http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html#c2
https://en.m.wikipedia.org/wiki/Damping_ratio
Short answer: no.
Pretty much for the reasons you state: too many variables.
You end up using catalogs of material properties to make guesses, then refine for the specifics.
If you need a particular damping coefficuent, you build that part to be close and tuneable.
Also the damping coefficient for an isolated perfect string is not a very useful thing to know even if you could work it out . A string in an actual instrument will behave quite differently anyway since it is interacting with the complex response of the sound box and other components .
Sometimes the best model we can do is the ideal model: An instrument with no resonating chamber whose body, neck, and headstock are immovable, in an atmosphere (i.e. air) of static temperature, pressure, humidity, and therefore density, and viscosity. I will even look at the change in the force of gravity with a change in height above sea level if I need to. At this point in time I am honestly not interested in how the string interacts with the body, but how the string interacts with the atmosphere itself. The guitar's body, neck, and headstock are a different elements that come together. Guitars vary a lot more than strings do.
I'm honestly not afraid to do a little lookup for material values if need be. I've done it before for projects very much related to this.
https://courses.physics.illinois.edu/phys406/Student_Projects/Fall00/STreharne/STreharne_P398EMI_Final_Report.pdf
The hope- the goal of all of this is so that as people *do* write equations for the behavior of the neck, or the headstock, or the truss rod, the body, and the resonating chamber, they can just drop this one in place and be done that much faster, kind like making a seatbelt so that when there is need of one the other person can just take it use it, instead of having to piece one together themselves.
  • · Replies 75 ·
  • Sticky
  • · Replies 0 ·
12K
11K
