Prime numbers and divisibility by 12
5 replies · 2K views
Philip Robotic
Prove that if ##p## is a prime number and if ##p>5## then ##p^2-37## is divisible by ##12##
So I think that the number ##p^2-37## should be expressed in a way that we can clearly see that it is divisible by 3 and by 2 twice (because ##2\cdot 2\cdot 3=12##). I tried modifying the original expression into something like this: $$p^2-37=12k$$ Where ##k## is a natural number, but got stuck here.
I also tried doing something with this: ##(p-\sqrt{37})\cdot (p+\sqrt{37})## but what next?
I think I am missing a step where I could use some of the properties of prime numbers, but I have really no idea where and how. I've been trying to solve this task for a pretty long time already, unfortunately whiteout success.
I would suggest considering the two possible crimes in terms of ##4 : 4k+1, 4k+3 ## , or maybe easier conceptually but longer, the primes ## 12k+1, 12k+5, 12k+7, 12k-1 ## (last is the same as ##12k+11.)##
Just a couple of observations, to emphasise why the other comments above are so important.
You really should have noticed that ##p^2 - 37## being divisible by 12 is equivalent to ##p^2 -1## being divisible by 12. That's a big lesson to learn from this! Whenever you are looking at divisible by ##n##, always think modulo ##n##.
Second, how generally true is this? Are there other numbers for which ##p^2 - 1## is always divisible by them? You might like to try to find some. But, perhaps this is a very specific result. It doesn't work for ##n = 10## or ##n = 14## or ##n =16##. Only ##n = 12##. Although, actually, it works for ##n = 24## as well!
So, maybe a "proof" here is just working through the small number of options for primes module 12? This is called a proof by "exhaustion".
My point is that this is another important lesson: sometimes, especially in these sort of problems, the best solution may simply be to go through all the options.
It seems to me that two observations will essentially get you there.
1. Any prime number greater than 2 is an odd number. I.e. p = 2k + 1 .
2. Any prime number greater than 3 is not divisible by 3, so it's congruent to ±1 mod 3 .
True. I start getting upset when I hear , usually profs., rejecting solutions that are not " elegant ' enough. Hey, when solving hard problems becomes second nature I will start worrying about my solutions being elegant.
