Probably obvious complex analysis question
The discussion centers on evaluating the complex integral \(\int_{|z| = 2} \sqrt{z^2 - 1}\). Participants identify that the integrand has branch points at \(z = -1\) and \(z = 1\), and a simple pole at infinity. The integral can be evaluated by deforming the contour around the branch cut along the real axis, leading to the conclusion that the integral evaluates to \(i\pi\). The use of logarithmic functions and branch cuts is emphasized as crucial for correctly handling the multi-valued nature of the integrand.
  • Complex analysis, particularly contour integration
  • Understanding of branch points and branch cuts in complex functions
  • Familiarity with logarithmic functions in complex analysis
  • Knowledge of Taylor series expansions and their applications
  • Study the properties of branch points and branch cuts in complex functions
  • Learn about contour integration techniques in complex analysis
  • Explore the application of the residue theorem in evaluating complex integrals
  • Investigate the relationship between logarithmic functions and multi-valued functions in complex analysis
Students and professionals in mathematics, particularly those focusing on complex analysis, as well as anyone interested in advanced calculus techniques for evaluating integrals involving multi-valued functions.
Mystic998
\sqrt{z^2 - 1} = e^{\frac{1}{2} log(z+1) + \frac{1}{2} log(z - 1)}
Honestly, my only thoughts are expanding this as some hideous Taylor series and integrating term by term. But I know there has to be a simpler way to go about it. I tried to find an antiderivative (with a little Calculus 2 cheating), but I got \frac{1}{2}(z\sqrt{z^2 - 1} - log(z + \sqrt{z^2 - 1})), which may or may not be correct (I took the derivative, saw the horrendous expression that came out, and my brain immediately shut down). But even if it is, choosing an appropriate branch for the log function seems like it would be kind of tricky.
Anyway, suggestions would be appreciated. Thanks.
Trig substitution comes to mind.
That's how I got the "antiderivative" I mentioned, but if that's right then I really have no idea how to choose the right branch of the logarithm. Do I have to see what z + \sqrt{z^2 - 1} does to my path?
Let me see if I am interpreting your integral symbol correctly: It's a closed line integral around the circle |z|=2 in the complex plane. Right? Which would be zero if the integrand was analytic, but it's not (the value is actually something like \pi i, i think) so we should consider the types of singularities of the integrand... I believe I know how to do this integral so I'll be a little Socratic now, even though it pains me to be so:
The integrand has branch points, where are they?
You interpreted correctly.
Anyway, I think the branch points all lie on the real axis less than or equal to 1, assuming we're using the principal branch of the log.
Well, you're right that the branch points of
<br /> \sqrt{z^2-1}<br />
all lie on the real axis... But where, exactly?
Well, log(z) has its branch points for z less than or equal to zero, so we get branch points for log(z^2 - 1) whenever z^2 - 1 \leq 0. So I guess it's -1 \leq z \leq 1?
just look at the given function
<br /> \sqrt{z^2-1}\;.<br />
The polynomial under the square root can be factored very easily to see where the two branch points are.
I don't quite understand what a branch point is apparently. I mean, as I understand it, yes, -1 and 1 are branch points, but I thought that any point where the multi-valued "function" actually started to be multi-valued was a branch point.
Oh well, -1 and 1 is the answer you're looking for I suppose.
yes, the function of interest has two branch points: one at -1 and one at +1. It also has a simple pole at infinity. An appropriate branch cut may run along the real axis from -1 to +1 (connecting the branch points). The contour (|z|=2) can be deformed without changing the value of the integral by shrinking it down without crossing the cut. we can shrink it down very far until it just wraps around the cut. the value of the integral is twice the integral just above the cut from -1 to +1. I.e., 2 \int_{-1}^{1}dx \sqrt{x^2-1}=i\pi.
Well, we haven't officially discussed path homotopy and its implications for contour integration yet (much to my chagrin), but I think I'm getting the idea. I think I could look at log(\frac{z+1}{z-1}), then maybe use that to define a square root in the region I want.
Anyway thanks.
  • · Replies 17 ·
