Problem about Nitrate electrodeposition
  • Thread starter Thread starter cuigm371
10 replies · 3K views
cuigm371
Hey guys,
I am preparing a technical exam and am facing an exam problem below:
Ni is electrodeposited from an aqueous sulphate solution that has a composition that fluctuates from 1 to 0.01M due to changes in the feed composition of the process.
a) what is the pH range that this electrodeposition can be conducted in order to avoid hydrogen gas evolution and nickel hydroxide precipitation? Given:
Ni 2+ + 2e- <-> Ni , E0 = -0.25V
Ni 2+ + 2H2O <-> Ni(OH)2 (s) + 2H+ log K = -12.73
Ksp= [Ni(OH)2] * [H+]^2/[Ni+]
a. pH range: take Eh-PH of H2O with respect to H2/H+ where:
[H2/H+] = -0.0592 pH = E0 = -0.25 V
so pH = 0.25/0.0592 = 4.22 to avoid hydrogen gas evolution
For Ni(OH)2 precipitation:
Ksp= [Ni(OH)2] * [H+]^2/[Ni+]^2 = 10^(-12.73)
this is where I was stuck- how to calculate the [Ni(OH)2] and the [Ni+]? using 1M and 0.01M respectively?
Borek said:
Your formula for Ksp is wrong.
Thank you for pointing out. the formula should've been:
Ksp= [Ni(OH)2] * [H+]^2/[Ni+] = 10^(-12.73)
I still am not clear what to do next. Could you please advise?
No, this is still not a correct formula for solubility product. It is not a matter of a wrong exponent, it is conceptually wrong (and that's what stops you from solving the problem).
Ni(OH)2 <-> Ni 2+ + 2 (OH)-
and Ksp = [Ni2+] [OH-]^2/[Ni(OH)2]
this seems more reasonable. Correct?
No, you are making the same error again and again. Please check with your textbook.
I believe it is right as below. THANK YOU VERY MUCH!
H+ + OH- = H2O Kw
Ni(OH)2= Ni2+ + 2OH- Ka
so, for Ni2+ + 2H2O = Ni(OH)2 + 2H+
K = Kw^2/Ka
Borek said:
Refer to the textbook page attached.
Ni(OH)2 = Ni2+ + 2(OH)-
Ks = [Ni]2+ x (OH)-^2 = 10^(-12.73)
Ni+ ranges from 1 to 0.01M, so OH- can be calculated accordingly. Is this right now?
Yes, when you have a correct formula for Ksp it is as trivial as solving for OH- and converting it to pH.
Thank you very much indeed!
looking back I think I was confused initially by the way it was given,
and forgot to go to the definition of the solubility product. this is a good lesson learned.
