What values of alpha make these curves tangent?
  • Thread starter Thread starter Ackbach
The discussion focuses on determining the values of $\alpha$ for which the curves defined by the equations $y = \alpha x^2 + \alpha x + \frac{1}{24}$ and $x = \alpha y^2 + \alpha y + \frac{1}{24}$ are tangent to each other. The analysis reveals that there are four specific values of $\alpha$: approximately $-0.9596$, $0.6667$, $1.5$, and $3.1263$. The solutions were derived through differentiation and solving quadratic equations, confirming that the curves touch at points where their gradients are equal.
  • Understanding of calculus, specifically differentiation and gradients.
  • Familiarity with quadratic equations and their solutions.
  • Knowledge of curve analysis and tangency conditions.
  • Basic proficiency in algebraic manipulation and factorization.
  • Explore the concept of curve tangency in multivariable calculus.
  • Study the application of the quadratic formula in solving polynomial equations.
  • Learn about graphical representations of functions and their intersections.
  • Investigate the implications of parameter variations on curve behavior.
Mathematicians, calculus students, and educators interested in curve analysis and tangency conditions, as well as anyone looking to deepen their understanding of polynomial functions and their properties.
Ackbach
MHB
Here is this week's POTW:
Find all values of $\alpha$ for which the curves $y = \alpha x^2 +\alpha x + \dfrac{1}{24}$ and $x = \alpha y^2 + \alpha y + \dfrac{1}{24}$ are tangent to each other.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to Opalg and castor28 for their correct solutions to this week's POTW, which was Problem A-1 in the 2007 Putnam Archive. Opalg's solution follows:
[sp]
If the curves $$(1)\qquad y = \alpha x^2 + \alpha x + \tfrac1{24}$$ and $$(2)\qquad x = \alpha y^2 + \alpha y + \tfrac1{24}$$ touch at the point $(x,y)$ then they must have the same gradient at that point. So, differentiate the equations to get $y' = 2\alpha x + \alpha$ and $1 = (2\alpha y + \alpha)y'$. Therefore $$(3)\qquad 1 = \alpha^2(2x+1)(2y+1).$$ Next, subtract (2) from (1) to get $y-x = \alpha (x^2 - y^2) + \alpha(x-y),$ which factorises as $$(4)\qquad (x-y)\bigl(\alpha(x+y+1) + 1\bigr) = 0.$$ One of the factors in (4) must be zero, so there are two cases to look at.Case 1: $x-y=0$. In that case, (3) becomes $$(5)\qquad \alpha(2x+1) = \pm1.$$ Substitute that in (1) (and use the fact that $y=x$) to get $$x = \pm\frac{x^2+x}{2x+1} + \frac1{24},$$ $$ 2x^2 + x = \pm(x^2+x) + \tfrac1{24}(2x+1).$$ There are then two subcases, depending on which $\pm$ sign is used.
Subcase 1+. If $ 2x^2 + x = x^2+x + \tfrac1{24}(2x+1)$ then $x^2 - \frac1{12}x - \frac1{24} = 0$, a quadratic with solutions $x = \frac14$ and $x = -\frac16.$ The corresponding values for $\alpha$ are given from (5) as $\alpha = \frac23$ and $\alpha = \frac32$.
Subcase 1-. If $ 2x^2 + x = -(x^2+x) + \tfrac1{24}(2x+1)$ then $24(3x^2 + 2x) = 2x+1$, so $72x^2 + 46x - 1 = 0.$ This time the quadratic does not factor neatly. So you have to use the formula to get the solutions as $x = \dfrac{-23 \pm\sqrt{601}}{72}.$ The corresponding values for $\alpha$ are given from (5) as $\alpha = \dfrac{-36}{13 \pm\sqrt{601}}.$
The other possibility from (4) is
Case 2: $\alpha(x+y+1) = -1$. Square that equation, to get $\alpha^2(x+y+1)^2 = 1$. Comparing that with (3), you see that $(x+y+1)^2 = (2x+1)(2y+1).$ Therefore $$x^2 + 2xy + y^2 + 2x + 2y + 1 = 4xy + 2x + 2y + 1,$$ $$ x^2 - 2xy + y^2 = 0,$$ $$ (x-y)^2 = 0.$$ So $x=y$, and Case 2 reduces to Case 1.
In conclusion, there are four values of $\alpha$ for which the given curves are tangent to each other. Their (approximate) numerical values are $-0.9596$, $0.6667$, $1.5$, $3.1263$. You can see them geometrically by dragging the slider in this graphic: [DESMOS]advanced: {"version":5,"graph":{"squareAxes":false,"viewport":{"xmin":-2.5,"ymin":-2.5,"xmax":2.5,"ymax":2.5}},"expressions":{"list":[{"id":"graph1","type":"expression","latex":"y\\ =\\ ax^2\\ +\\ ax\\ +\\ \\frac{1}{24}","color":"#2d70b3"},{"id":"2","type":"expression","latex":"x\\ =\\ ay^2\\ +\\ ay\\ +\\ \\frac{1}{24}","color":"#388c46"},{"id":"3","type":"expression","latex":"a=3.14","hidden":true,"color":"#fa7e19","sliderMin":"-2","sliderMax":"4","sliderHardMin":true,"sliderHardMax":true,"sliderInterval":"0.01"}]}}[/DESMOS]
[/sp]
