How Can We Find All Integer Pairs (k, n) That Satisfy This Factorial Equation?
  • Context: High School
  • Thread starter Thread starter anemone
The discussion focuses on finding all pairs of positive integers (k, n) that satisfy the factorial equation k! = (2^n - 1)(2^n - 2)(2^n - 4)...(2^n - 2^(n-1)). The analysis reveals that for n ≥ 5, n must be less than or equal to 5, leading to the conclusion that the only valid solutions are (1, 1) and (3, 2). The discussion employs mathematical inequalities and properties of factorials to derive these results, emphasizing the relationship between k and n through the constraints established by the equation.
  • Understanding of factorial notation and properties
  • Familiarity with exponential functions and their properties
  • Knowledge of inequalities and their applications in mathematical proofs
  • Basic concepts of number theory, particularly regarding divisibility
  • Explore the properties of factorial growth rates and their implications on integer solutions
  • Study the application of inequalities in combinatorial mathematics
  • Investigate the concept of d_2(m) and its relevance in number theory
  • Learn about advanced techniques in solving Diophantine equations
Mathematicians, students studying number theory, and anyone interested in combinatorial mathematics and the properties of factorials.
anemone
MHB
POTW Director
Here is this week's POTW:
Find all pairs of positive integers $(k,\,n)$ such that $k!=(2^n-1)(2^n-2)(2^n-4)\cdots(2^n-2^{n-1})$.
LHS= ##k! >(\frac ke)^k\sqrt{2\pi k}\frac 1{e^{12k+1}}##
RHS##=(2^n-1)(2^n-2)(2^n-4)\cdots(2^n-2^{n-1})##
##=(2^n)^n\Pi_1^n(1-2^{-r})##
##=2^{n^2}e^{\Sigma_1^n\ln(1-2^{-r})}##
##<2^{n^2}e^{\Sigma_1^n-2^{-r}}##
##=2^{n^2}e^{-1}##
So ##(\frac ke)^k\sqrt{2\pi k}\frac 1{e^{12k+1}}<2^{n^2}e^{-1}##
##(\frac ke)^k<2^{n^2}##
Define ##d_2(m)## as the number of times 2 divides m.
##\frac 12k<d_2(LHS)<k##
##d_2(RHS)=\frac 12n(n-1)##
Hence ##k<n(n-1)<2k##
If ##n\geq N## then ##n^2\frac{N-1}N<n(n-1)<2k##.
##(\frac ke)^k<2^{2k\frac N{N-1}}##
##k<2^{2\frac N{N-1}}e##
With N=5 this yields
##k\leq 15##
##n<6##
Thus, if ##n\geq 5, n\leq 5##, hence ##n\leq 5##.
I haven't been through all the possibilities yet.. no time now … but the only two solutions that are obvious are n=1, k=1; n=2, k=3.
Here's an informal argument:
Let $$a(n) =(2^n-1)(2^n-2)(2^n-4)\cdots(2^n-2^{n-1})$$And note that$$a(n) = (2^n-1)(2^{n-1})a(n-1)$$If we let ##t(n)## be the powers of ##2## in the prime factorisation for ##a(n)## then we see that:$$t(n) = \frac{n(n-1)}{2}$$And note that ##t(n)## increases rapidly with ##n##.
Now we look at the powers of ##2## in ##k!## and we note that this increases much less rapidly.
In any case, we can look for the factorials that have the same power of ##2## for the relevant ##n##. E.g:
$$n = 5, t(n) = 10, k = 12 \ \text{or} \ 13$$We can check that ##a(n) \ne k!## in these cases. The next cases are:
$$n = 6, t(n) = 15, k = 16 \ \text{or} \ 17$$$$n = 7, t(n) = 21, k = 24 \ \text{or} \ 25$$And for this value of ##n## the possible values of ##k!## are already much greater than ##a(n)##. If we keep going:
$$n = 8, t(n) = 28$$ there are no possible values of ##k##
$$n = 9, t(n) = 36$$ there are also no possible values of ##k##. Moreover, for the nearest values of ##k## we see that ##k!## is now much larger than ##a(n)## it's clear that there can be more solutions.
You could look more formally at how ##a(n)## and the possible values of ##k## are increasing to formalise the argument somewhat.
I only came up with this after reading the other solutions, so it's not very original but I think hits the heart of the problem.
for ##0<j<2^{n-1}##, ##j## and ##2^{n-1}+j## have the same number of factors of ##2## - if ##2^a|j## then ##j<n-1## so ##2^a | 2^{n-1}##, and hence ##j = j+2^{n-1}## mod ##2^a##
Matching ##2^{n-1}+1## with ##1## all the way through ##2^{n}-1## with ##2^{n-1}-1##, we see the product in the question has the same number of 2s as ##2^{n-1}!##This doesn't agree with perok's numbers, for ##n=7## this gives ##k=64##, but wolfram alpha agrees these both are divisible by ##2^{63}##
https://www.wolframalpha.com/input?i=factor+(2^6)!
https://www.wolframalpha.com/input?i=factor+(2^7-1)!/(2^6-1)!
So ##k## must be ##2^{n-1}## or ##2^{n-1}+1##. For ##k=1## these products are the same. For ##k=3## you also get equality. In general in our mapping of numbers in the ##(2^n-1)!/(2^{n-1}-1)!## to the numbers in ##2^{n-1}!## to establish the power of 2 correpondence, each number in the former was at least twice as large as the latter except for the ##2^{n-1}## which we didn't map to a smaller number since it's in both products, so to get equality you need ##k=1##, or you need##k=2^{n-1}+1## to get an extra factor to try to catch up. But even then we just get an extra factor of ##2^{n-1}+1## when we're trying to compete with ##2^{n-1}-1## extra powers of two (so a factor of 2 raised to that quantity). So we need ##n-1 \geq 2^{n-1}-1## which is only true for ##n=1## or ##n=2##.
Here's a simpler informal argument:
Let $$a(n) =(2^n-1)(2^n-2)(2^n-4)\cdots(2^n-2^{n-1})$$And note that$$a(n) = (2^n-1)(2^{n-1})a(n-1)$$We can now analyse the prime factors of ##a(n)## recursively by looking at the sequence ##2^n-1##:
$$3, 7, 15, 31, 63, 127 \dots$$Immediately, we see that prime numbers like ##31## and ##127## appear early in the factorisations. But, don't appear in ##k!## until ##k =31## or ##k = 127## respectively.
It's clear (although not so easy to prove formally) that this sequence can never produce another factorial for larger ##n##. It has far too many powers of ##2## compared to the other primes and has larger primes appearing too early in the sequence.
