Is the product of two radical expressions equal to six?
  • MHB
  • Thread starter anemone
In summary, the general rule for multiplying radical expressions is to first simplify each expression, then multiply them together and simplify the resulting product. There are special cases where the product of two radical expressions is equal to six, such as when one expression is equal to 2 and the other is equal to 3. However, it is not possible for the product of two radical expressions to be equal to a negative number. It is also possible to have more than one solution for the product of two radical expressions equal to six. To check if the product is equal to six, you can simplify each expression, multiply them together, and then simplify the resulting product to see if it equals six.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Prove that $\sqrt{4+\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}} \cdot \sqrt{8+2\sqrt[3]{19+3\sqrt{33}}+2\sqrt[3]{19-3\sqrt{33}}}=6$.
Likes I like Serena and topsquark
Please clarify the problem. Wolfram Alpha says this is not 6. Thanks.
Likes topsquark and malawi_glenn
I've checked with W|A and it confirms that it is really 6.
Note that W|A treats every input as complex valued and takes the principle complex root by default, while in this case the real valued root is intended. That is, we need that $\sqrt[3]{-1}=-1$ instead of $\sqrt[3]{-1}=e^{i\pi/3}$.
Likes Wrichik Basu, anemone, jim mcnamara and 2 others
Thanks @I like Serena for the reply!
Likes malawi_glenn and I like Serena
All the terms except
[tex](-26-6\sqrt{33})^{1/3}[/tex]
are real. I do not believe this equation holds. Should I interpret it with real coefficient -1
[tex]-(26+6\sqrt{33})^{1/3}[/tex]
not with complex coefficients, i.e.
[tex]e^{\pi i/3},e^{-\pi i/3}[/tex]
[EDIT] I got it in the post #4. Thanks.
This is just to know I got the question properly. LHS of the to be proved equation is
[tex]L:=2^{2/3}[2^{5/3}+(a-13)^{1/3}-(a+13)^{1/3}]^{1/2}[2^2+(19+a)^{1/3}+(19-a)^{1/3}]^{1/2}[/tex]
where
[tex]a=3\sqrt{33}=17.23...[/tex]
We may make use of the relations
[tex](a+13)(a-13)=a^2-13^2=128=2^7[/tex]
[tex](a+19)(19-a)=19^2-a^2=64=2^6[/tex]
For an example
[tex][2^2+(19+a)^{1/3}+(19-a)^{1/3}]^{1/2}=(19+a)^{1/6}+(19-a)^{1/6}[/tex]
Likes Maarten Havinga
Is this problem workable without infinite series expansions?
So far after spending too many hours on this I wonder if there is a doable closed form proof. Of course one can evaluate this easily with computer tools like Wolfram Alpha but proof is not the same thing. The cube roots are all irrational numbers.
I did notice that
$$\sqrt[3]{-26+6\sqrt{33}}*\sqrt[3]{-26-6\sqrt{33}} = -8$$
and $$\sqrt[3]{19+3\sqrt{33}}*\sqrt[3]{19-3\sqrt{33}}=4$$
I have tried everything. When will the proof be posted?
Likes malawi_glenn
I am so sorry for the late reply to this POTW's thread as I have been so extremely busy with work.
Here is the solution of other and I hope that readers will appreciate the beauty of the solution as much as I do.
Let $x=\sqrt[3]{a+\sqrt{b}}+\sqrt[3]{a-\sqrt{b}}$ so that we get $x^3-3\sqrt[3]{a^2-b}x-2a=0$.
Now, let $p=\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}$ and $q=\sqrt[3]{19+3\sqrt{33}}+\sqrt[3]{19-3\sqrt{33}}$. We then obtained $q^3-12q-38=0$ and $p^3+24p+52=0$.
Then what we are required to prove becomes $(4+p)(4+q)=18$.
It is then not hard to prove that both $q^3-12q-38=0$ and $p^3+24p+52=0$ have only one real roots.
That means $4+q$ and $4+p$ are the only real root of the polynomials $f(x)=(x-4)^3-12(x-4)-38=x^3-12x^2+36x-54$ and $g(x)=(x-4)^3+24(x-4)+52=x^3-12x^2+72x-108$.
So we have $f\left(\dfrac{18}{x}\right)=-\dfrac{54}{x^3}g(x)$, i.e. $f\left(\dfrac{18}{4+p}\right)=g(4+q)=0$.
Hence, $\dfrac{18}{4+p}=4+q$ and the proof follows.
Likes bob012345, anuttarasammyak and Greg Bernhardt
For confirmation of post#11
Thanks. Before I look at it I want to report on the direction I took but I could not finish it.
$$\sqrt{4+\sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}} \cdot \sqrt{8+2\sqrt[3]{19+3\sqrt{33}}+2\sqrt[3]{19-3\sqrt{33}}}=6$$
Let $$z= \sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}$$ and
$$z' = \sqrt[3]{19+3\sqrt{33}}+\sqrt[3]{19-3\sqrt{33}}$$
we can write it as
$$\sqrt{4+z} \cdot \sqrt{8+2z'}=6$$
or $$32 + 8z + 8z' + 2zz' = 36$$
solving for z' we get
$$z' = \frac{2 - 4z}{4 + z}$$
we put in z in the expression
$$z' = \frac{2 - 4\sqrt[3]{-26+6\sqrt{33}} -4\sqrt[3]{-26-6\sqrt{33}})}{4 + \sqrt[3]{-26+6\sqrt{33}}+\sqrt[3]{-26-6\sqrt{33}}}$$
then try and simplify. Wolfram Alpha says it does simplify to exactly z' but so far I have not been able to do it.
[\SPOILER]
I finally have finished my proof in a direct form.
given
write it as
$$\sqrt{4+ a + b} \sqrt{8+2c + 2d} = 6$$
expand
$$ \sqrt{32 + 8(a + b + c + d) + 2(ac + ad + bc + bd)} = 6$$
then
##a = \sqrt[3]{-26 + 6\sqrt{33}}\hspace{0.5cm} b= \sqrt[3]{-26 - 6\sqrt{33}}\hspace{0.5cm}c = \sqrt[3]{19 + 3\sqrt{33}} \hspace{0.5cm}d= \sqrt[3]{19 - 3\sqrt{33}}##
Details of the working out of these expressions are in the appendix below.
##ac = 1 + \sqrt{33}\hspace{0.5cm}bd = 1 - \sqrt{33}\hspace{0.5cm}ad = -4\sqrt[3]{17-3\sqrt{33}}\hspace{0.5cm}bc = -4\sqrt[3]{17+3\sqrt{33}}##
Evaluating the sum of terms it is convenient to add ##a+d## and ##b+c## separately.
##a + d = \sqrt[3]{17+3\sqrt{33}}\hspace{0.5cm}b + c = \sqrt[3]{17-3\sqrt{33}}##
therefore
$$ \sqrt{32 + 8\sqrt[3]{17+3\sqrt{33}}) +8\sqrt[3]{17-3\sqrt{33}}+ 2\left( 1 + \sqrt{33} + 1 - \sqrt{33} -4\sqrt[3]{17+3\sqrt{33}} -4\sqrt[3]{17-3\sqrt{33}}\right)} = 6$$
giving
$$ \sqrt{32 + 4} = \sqrt{36} = 6$$
Appendix:
Again;
$$ac = \sqrt[3]{-26 + 6\sqrt{33}} \sqrt[3]{19 + 3\sqrt{33}} = \sqrt[3]{-26*19 +18*33 +(6*19-3*26)\sqrt{33}} = \sqrt[3]{100 + 36\sqrt{33}} = \sqrt[3]{(1 + \sqrt{33})^3} = 1 + \sqrt{33}$$
likewise
$$bd = \sqrt[3]{-26 - 6\sqrt{33}} \sqrt[3]{19 - 3\sqrt{33}} = \sqrt[3]{-26*19 +18*33 +(-6*19+3*26)\sqrt{33}} = \sqrt[3]{100 - 36\sqrt{33}} = \sqrt[3]{(1 - \sqrt{33})^3} = 1 - \sqrt{33}$$
$$ad = \sqrt[3]{-26 + 6\sqrt{33}} \sqrt[3]{19 - 3\sqrt{33}} = \sqrt[3]{-26*19 -18*33 +(6*19+3*26)\sqrt{33}} = \sqrt[3]{-1088 + 192\sqrt{33}} = \sqrt[3]{64(-1 7+ 3\sqrt{33})} = -4\sqrt[3]{17 - 3\sqrt{33}}$$
likewise
$$bc = \sqrt[3]{-26 - 6\sqrt{33}} \sqrt[3]{19 + 3\sqrt{33}} = \sqrt[3]{-26*19 -18*33 -(6*19+3*26)\sqrt{33}} = \sqrt[3]{-1088 - 192\sqrt{33}} = \sqrt[3]{64(-1 7- 3\sqrt{33})} = -4\sqrt[3]{17 + 3\sqrt{33}}$$
Now for the sum ##(a + d)## we use the relation ##(a + d)^3 = a^3 + d^3 +3a^2d + 3ad^2##
##a^2d = a (ad) = -4\sqrt[3]{(-26 + 6\sqrt{33})(17 - 3\sqrt{33})} = -4\sqrt[3]{-1036 + 180\sqrt{33}} = \sqrt[3]{66304 - 11520\sqrt{33}} = \sqrt[3]{(28 - 4\sqrt{33})^3} = 28 - 4\sqrt{33}##
##ad^2 = (ad)d = -4\sqrt[3]{(17 - 3\sqrt{33})(19 - 3\sqrt{33})} = -4\sqrt[3]{620 - 108\sqrt{33}} = -\sqrt[3]{39680 - 6912\sqrt{33}} = \sqrt[3]{(-20 + 4\sqrt{33})^3} = -20 + 4\sqrt{33}##
so ##(a + d)^3 = -26 + 6\sqrt{33} + 19 - 3\sqrt{33} +3(28 - 4\sqrt{33}) + 3( -20 + 4\sqrt{33}) = -7 +3\sqrt{33} +84 -12\sqrt{33} -60 +12\sqrt{33} = 17 +3\sqrt{33}##
thus ##(a + d) = \sqrt[3]{ 17 +3\sqrt{33}}##
Likewise for the sum ##(b + c)## we use the relation ##(b + c)^3 = b^3 + c^3 +3b^2c + 3bc^2##
##b^2c = b (bc) = -4\sqrt[3]{(-26 - 6\sqrt{33})(17 + 3\sqrt{33})} = -4\sqrt[3]{-1036 - 180\sqrt{33}} = \sqrt[3]{66304 + 11520\sqrt{33}} = \sqrt[3]{(28 + 4\sqrt{33})^3} = 28 + 4\sqrt{33}##
##bc^2 = (bc)c = -4\sqrt[3]{(17 + 3\sqrt{33})(19 + 3\sqrt{33})} = -4\sqrt[3]{620 + 108\sqrt{33}} = -\sqrt[3]{39680 + 6912\sqrt{33}} = \sqrt[3]{(-20 - 4\sqrt{33})^3} = -20 - 4\sqrt{33}##
so ##(b + c)^3 = -26 - 6\sqrt{33} + 19 + 3\sqrt{33} +3(28 + 4\sqrt{33}) + 3( -20 - 4\sqrt{33}) = -7 -3\sqrt{33} +84 +12\sqrt{33} -60 -12\sqrt{33} = 17 -3\sqrt{33}##
thus ##(b + c) = \sqrt[3]{ 17 -3\sqrt{33}}##
[\SPOILER]
1. What is a radical expression?
A radical expression is an expression that contains a radical symbol (√) and a radicand, which is the number or variable inside the radical symbol. Examples of radical expressions include √2, √x, and √(3x+4).
2. How do you multiply two radical expressions?
To multiply two radical expressions, you can use the product rule, which states that the product of two radicals is equal to the radical of the product of their radicands. For example, √a * √b = √(ab).
3. Can the product of two radical expressions be simplified?
Yes, the product of two radical expressions can be simplified if the radicands have common factors. You can simplify by factoring out the common factor and taking the square root of the remaining factor. For example, √12 * √3 = √(4*3) * √3 = 2√3 * √3 = 2*3 = 6.
4. Is the product of two radical expressions always equal to six?
No, the product of two radical expressions is not always equal to six. It depends on the radicands of the two expressions. If the radicands are not factors of six, then the product will not be equal to six. For example, √5 * √7 = √(5*7) = √35, which is not equal to six.
5. Can the product of two radical expressions be equal to six if one of the radicands is negative?
No, the product of two radical expressions cannot be equal to six if one of the radicands is negative. This is because the square root of a negative number is not a real number. Therefore, the product of two radical expressions will not be a real number and cannot be equal to six.
  • Math POTW for Secondary and High School Students
