Problem with dot product of vectors
cshum00
It began in class with this problem.
Find the dot product of 2 vectors:
v1 a vector with components <4, 8>
v2 a vector of length 1 angle pi/4
So, i have 2 ways of doing it.
1) v1.v2 = v1x.v2x + v1y.v2y
2) v1.v2 = |v1||v2|cos(theta)
And they should come out the same but.
1) v1.v2 = 4cos(pi/4) + 8sin(pi/4) = 6√(2)
1) v1.v2 = √(42 + 82)cos(pi/4) = 2√(10)
and 6√(2) ≠ 2√(10), so i wondered if i did something wrong. Then it tried different numbers and found out these two ways of computing the dot product of two vectors are never the same for an angle pi/4 except for vectors with components <a, 0> or <0, a> where a is any real number.
I wonder if i computed anything wrong causing different results or is is that they are not the same?
Hi cshum00!
(have a pi: π and a theta: θ and a root: √ :smile:)
θ is the angle between the two vectors.
If v2 is at π/4 to the x-axis, it is at (1/√2,1/√2), but the angle between it and (4,8) is not π/4. :smile:
I see so it means that, v1x.v2x + v1y.v2y = |v1||v2|cosθ is true only if v1 or v2 is on the x-axis and therefore the angle making between them is θ.
Thanks, it clarifies at lot.
Stop!
No, θ in that formula has nothing to do with the x-axis.
θ is the angle between whatever two vectors you're dot-producting. :smile:
|v1||v2|cosθ this formula doesn't but
v1x.v2x + v1y.v2y this formula does
so, if the angle of v2 is θ and
then v1 have to be in the x-axis
although now you cleared me that in the original problem, the angle in v2 was not θ but with the x-axis
thanks again
NO, v1 and v2 can be any two vectors, [itex]\theta[/itex] the angle between them. It is only if v1 lies on the (positive) x-axis that the angle between then is the angle v2 makes with the positive x-axis.
thanks again
Yes, you are right. I am making so much confusion with the angle given for v2 which is the one between v2 and the x-axis and not θ
